Question about Lexmark X4530 InkJet Printer
My Lexmark X4530 won't connect to my wireless network. It makes an Ad-hoc network of its own every time I go through the network setup on it. I want to connect it to the network instead of connecting to it's own network. How can I set it up? It doesn't give me options to change the network name in the printer.
  • Lexmark Care
    Lexmark Care May 09, 2017
    You should call on ((+1-800-585-2494 )) Toll Free Lexmark and get help for Lexmark.
  • 4 Answers
Posted on May 09, 2017
SOURCE: Lexmar 4875 Flatbed Wireless printer not connecting to the networ
I know you posted this in May, so have probably given up and bought a new printer by now, but I thought it worth mentioning that I had the same problem exactly (though without the same number of iphones and laptops!).
Buried away in some documentation on the driver CD, is the fact that the X4875 can't communicate with a secure wireless network that uses a TKIP algorithm - it can only handle AES. My router used TKIP out of the box, and I never thought to change is, especially as it's stronger than AES. However, changing it to AES solved the problem.
By the way, if you're using Vista, you may find that you have to run the install package in Windows XP compatibility mode, and then when the install is complete, manually change every .exe under c:\program files\lexmark\.. to run in XP compatibilty mode too. Works for me (Vista Business), but didn't work wirelessly at all before. Good luck,
Chris J.
Posted on Jul 13, 2009
professor_sc
  • 180 Answers
SOURCE: I have a laptop run
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Posted on Aug 05, 2008
SOURCE: wireless
I had the same problem. It is now working.
The problem was a bad conecction of the network interface card.
I simply pluged it out and inserted it in and it is now working fine !!
Hope it works for you.
Posted on Feb 08, 2009
Ajkill
  • 2035 Answers
SOURCE: lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Posted on Mar 26, 2009
  • 240 Answers
SOURCE: X4530 "communication not available" with laptop
I already experience it ..it becuase of the driver..I think you have 2 or more printer driver installed on your computer right??
you need to uninstall all exisiting driver and install again the printer driver...
and then..
after installing the driver
go to >programs
>printer and faxes
right click the printer icon ..
select used printer as default printer..
and right again..and select >use printer online..
Thank you for using FIXYA..
please a rate ..if it solve your problem..
good luck.
and thank you for choosing lexmark.
Posted on May 22, 2009
Why does connecting to an ad-hoc network disconnect the shared mobile broadband connection?
You can be connected to two signals at one time, if I understand your statement. My question is, why is your laptop automatically connecting to a Ad-Hoc network? Your wireless adapter Intel Wireless 3945A/B/G,settings should be scrutinized. Perhaps this will help:http://www.intel.com/p/en_US/support/highlights/wireless/pro3945abg
Dec 15, 2012 | IBM Lenovo ThinkPad Z61m 9452-J4U PC...
Tip
Set up a computer-to-computer (ad hoc) network
An ad hoc network is a temporary connection between computers and devices used for a specific purpose, such as sharing documents during a meeting or playing multiple-player computer games. You can also temporarily share an Internet connection with other people on your ad hoc network, so those people don’t have to set up their own Internet connections. Ad hoc networks can only be wireless, so you must have a wireless network adapter installed in your computer to set up or join an ad hoc network.
Click to open Connect to a Network.
Click Set up a connection or network.
Click Set up an ad hoc (computer-to-computer) network, click Next, and then follow the steps in the wizard.
Notes
If one or more of the networked computers is joined to a domain, you need to have a user account on that computer to see and access shared items on it.
If the networked computers are not joined to a domain, but you want to require people to have a user account on your computer for access to shared items, turn on password protected sharing in Network and Sharing Center.
To turn on password protected sharing
Click to open Network and Sharing Center.
Under Sharing and Discovery, if password protected sharing is off, click the arrow button to expand the section, click Turn on password protected sharing, and then click Apply. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
An ad hoc network is automatically deleted after all users disconnect from the network or when the person who set up the network disconnects and goes out of range of the other users of the network, unless you choose to make it a permanent network when you create it.
If you share your Internet connection, Internet connection sharing (ICS) will be disabled if you disconnect from the ad hoc network, you create a new ad hoc network without disconnecting from the old ad hoc network for which you enabled ICS, or you log off and then log back on (without disconnecting from the ad hoc network).
If you set up an ad hoc network and share your Internet connection, and then someone logs on to the same computer by using Fast User Switching, the Internet connection will still be shared, even if you didn't intend to share it with that person.
I hope you all found this information useful and helpful.
Phillip
on Jul 31, 2010 | Computers & Internet
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • Dec 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
    Is this is a wireless printer - how do I set up a wireless network from my new laptop to the printer?
    Yes your printer is wireless, there're two ways to connect it wirelessly, 1. Ad-Hoc Mode and 2. Infrastructure Mode.
    Your can check out the complete tutorials here..
    1. Infrastructure Mode wireless setup (recommended)
    2. Ad-Hoc Mode Wireless connection
    If you need further help, let me know.
    Good luck.
    Thanks for using FixYa.
    Sep 23, 2010 | HP LaserJet 1320 Printer
    I purchase a wireless interprets 405> Do i need a router foir the wireless
    X1270 is not a wireless printer...
    I find nothing on an Interprets 405...
    If you have purchased a wireless printer device, your computer will need a wireless card.
    If your computer has wireless built in and you have no router it is called an 'Ad Hoc' network. The printer must support an 'Ad Hoc' network or you will need a wireless router.
    'Ad Hoc' networks are notoriously insecure, so a wireless router is a very wise choice. It helps keep you safe from hackers on the Internet as well as it functions as a home firewall and network host.
    If this does not help, please give me more detail.
    Mar 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
    Home wireless network
    Most wireless1.gif networks are setup as infrastructure networks, meaning all communication is to/from a wireless access1.gif point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
    There is an alternate form of wireless networking1.gif refered to as ad hoc -- in this version of wireless networking every wireless adapter1.gif can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
    Based on this are you asking to create an ad hoc network to connect 2 PC's1.gif wirelessly without a wireless router1.gif or access to the internet from the wireless network (without a dedicated machine)?
    Dec 19, 2007 | Linksys Wireless-G Broadband Router
    Compaq n6120 - can't connect wireless
    Most wireless networks are setup as infrastructure networks, meaning all communication is to/from a wireless access point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
    There is an alternate form of wireless networking refered to as ad hoc -- in this version of wireless networking every wireless adapter can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
    Based on this are you asking to create an ad hoc network to connect 2 PC's wirelessly without a wireless router or access to the internet from the wireless network (without a dedicated machine)?
    Dec 19, 2007 | Dell Inspiron 6400 Notebook
    Lexmark X4530 InkJet Printer Logo
    1,081 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
