Question about Amana Ovens
Amana Gas Oven Model # ARG7303WW. We just purchased a home. It had been vacant for approximately 1-1/2 years. When we now use the oven,it takes double the time to bake anything. We set it on the temperature it should bake on; but the cooking time is doubled. Cookies should be 10 minutes at 375. We put the oven on 375 but it takes approx 20 minutes. For turkey, should be 3 hours. Ours can take almost 6 to cook it. Is this because the oven was not used for so long or ??? THANKS very much.
    Top Expert:
  • 5,673 Answers
Check burner tubes for clog
Posted on Oct 08, 2017
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
barkencoa
  • 3463 Answers
SOURCE: temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: oven tempture
The solution I am proposing here only applys to electric ovens and not micro wave ovens.
The usual reason for fluctuating oven temperatures is a faulty or out of calibration thermostat.
Some thermostats can be recalibrated, but in my experience, it is better to replace it.
Another reason for fluctuating temperatures is a badly fitting oven door, or a worn or faulty door seal, the door should be a good firm fit agaist the seal.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
SOURCE: Help! Trying to speedbake my turkey!! Lost instructions!
obviously your turkey has done for a LONG time. But for the future, the speed bake takes 30% less cook time
Posted on Mar 23, 2009
  • 323 Answers
SOURCE: Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
Posted on May 16, 2009
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
Mar 17, 2013 | Tappan Ovens
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
Ovens Logo
69 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
