Question about General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the panel neutral, the black load line to the gfci power side, the white load line to the Gfci white side, and the ground from the circuit side to the panel box neutral. Everthing works except the GFCI test button doesn't seem to work --- when depressed it doesn't shut the circuit down. The circuit breaker itself seems to work, but it doesn't seem to have any ground fault protection. Is the GFCI ciruuit breaker defective? Isn't this unusual to have everything work but the GF part of it?
  • highker11 Nov 15, 2010
    Good Advice - I will buy tester.
  • 760 Answers
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Posted on Nov 15, 2010
Installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
20 A AFCI Homeline trips intermittenly on a outlet circuit with no lighting on it. The circuit does have an GFCI outlet on it. Trips mabe once a week. replaced the breaker and it worked fine for about a...
You should not have multiple GFCI devices in any one circuit. Change out the outlet and label it
GFCI Protected if necessary...Your problem of nuisance trips should go away.
John
Sep 21, 2011 | Square D Co. QO120CAFIC ARC Fault Circuit...
Problems with a GFCI outlet (no voltage). GFCI outlet was replaced and reset recently but that didn't fix the problem. One other GFCI breaker in the same room is working OK. Also, water is entering...
if your room is powered by one breaker you need only one gfci and it has to be hooked up correctly to protect the other outlets a new gfci will have a tape tag over the out side usually the top set of nuts the water in the panel is a major fire hazard i would fix this problem first your feed to the gfci may have shorted out in the wall between the breaker and the gfci if it is wired separate from the other gfci in that room one thing you can do to save calling an electrician is go to lows home depot or any electrical store and purchase a plug in tester they are inexpensive and easy to use it will tell you if wires are hooked up correctly backwards or if you have a short somewhere in the line this is the same little gadget that an electrical inspector uses to make sure new homes are wired correctly an outlet will still work even if some wires are incorrect in the circuit the outlet tester confirms all is good and safe
Jan 23, 2011 | GE Hammering
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Outdoor Outlet Does Not Work
Your outdoor outlet(s) may already be ground faulted: often these outlets are fed from an existing GFCI outlet; check your bathroom(s) or kitchen for a GFCI receptacle. Use the tester he mentioned to see if it is live – be SURE to get a tester with the button on it that checks GFCI's as well – if the tester button kills the GFCI from any outlet on that circuit, you know the GFCI is working. Using the tester in your outdoor outlet verifies the GFCI AND the wiring to your outdoor outlet – something the GFCI's 'test' button can't do. ...Wilzard
Aug 08, 2009 | Rival S12T Electric Skillet
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge Logo
926 people viewed this question
Top General Electric Electrical Supplies Experts
Craig Butler
Craig Butler
David Harrelson
David Harrelson
Steve
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
