I need to connect a D-Link router to my cable modem so that I can use my laptop anywhere in my home
    Brigadier General:
  • 10,406 Answers
Cable-modem <-- Ethernet cable --> WAN (or "Internet") port on the router
LAN port on router <-- Ethernet cable --> network-port on your laptop
Then, access the "built-in" web-server on the router,
and run the "Wireless Networking Setup" wizard:
* to set an SSID ("network-name")
* an encryption-level (Hint: choose 'wpa')
* a password for your wireless network
Then, disconnect the Ethernet cable from your computer,
and then "wireless available wireless networks".
Select your newly-created network, and connect to it.
Posted on Nov 15, 2010
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
Tip
How to configure a wired/wireless home network
In this guide I will go over the steps needed to setup a basic home network. In this network, we will have a desktop computer, a wireless laptop, printer, router and cable modem.
*All devices should be turned off at this point*
1) The cable modem which is usually provided by your internet service provider, should be connected to your coaxial cable(broadband internet) that is active, and can be anywhere in your household. This modem can also be for DSL connections(phone line).
*If you only have one device you wish to connect to your home network, this device can plug directly into the modem and you will not need a router*
2) Next, you will need to connect the router to the modem. You will use a Cat5 cable to do this. It is also commonly referred to as a Ethernet cable or patch cable. On the modem, you will see a Ethernet port, plug one end of the cable to this port. On the router, you will see many Ethernet ports. The port you wish to use to connect the modem to the router is usually separated from the other ports and may be labeled (modem or internet). The ports labeled 1-6 for example are your LAN ports and normally for computers etc. So, plug the other end of the Ethernet cable into the port labeled modem or internet that is away from the other ports.
3) Now, for each device you wish to have wired network access(computers, laptops, game consoles) you will need to plug an Ethernet cord into each one, and plug the other end into one of the LAN ports on your router.
4) Power on the cable modem, wait 30 seconds then power on the router.
4) Next, you will need to power on your desktop in order to configure the router. Please consult your routers manual in order to do so.
5) Once your router is configured, you should be able to access it from any of your devices and these devices should have access to the internet. If you wish to have wireless access also, you will need to setup wireless security, password and a SSID. Your SSID is the name you give the router, and this is the name that will show up when you search for routers within range of your computer. Below is a picture of a list of wireless access point SSID.
6) At this point there are several ways to connect a printer. For simplicity, you can connect it to one of the computers, and give access to the other computers. The following guide will go over this step,
http://windows.microsoft.com/en-US/windows7/Install-a-printer
I hope this guide helps you in your quest to setup a basic home network. There are many factors that come into play and additional steps may need to be taking but this will get you started!
Regards,
G33k
on May 04, 2011 | Computers & Internet
My F5D7234 is not working w/ Windows 7. Watsup?
Is your modem connected to the main computer or the router ?
If the main computer is connected to the computer then you will need to connect the modem to the router .
Check the connections.
check the settings on the router.
I hoe the following link will help you.
Click Here for more info
Nov 09, 2009 | Belkin F5D7234-4 Router
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
