Question about KitchenAid Microwave Ovens
I have a new five burner cooktop that is scratched, what do I need to do to get the scratches removed?
  • 10,515 Answers
Kindly mention whether it has glass or ceramic cooktop?
Thanks!!
Posted on Nov 14, 2010
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
The cooktop burners have no spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jun 14, 2011 | Microwave Ovens
No spark on right front burner. the other burners work fine.
heatman101
Apr 03, 2011 | Microwave Ovens
I have a scratch on the top of my ceramic stovetop. How can I repair it?
Instructions for repairing scratches on ceramic cooktop
Things You'll Need:
  • Nonabrasive cleaner
  • Dishwashing liquid
  • Cloth
  • Razor scraper
  • Ceramic crème
  • Sponge or cloth(s)
  1. 1 Clean the cooktop with a nonabrasive cleaner, such as a glass cleaner or warm water mixed with a few drops of dishwashing liquid. Wipe with a clean, soft cloth.
  2. 2 Use your fingernail or the flat edge of a razor scraper to remove any raised surfaces on the scratch.
  3. 3 Apply a ceramic repair crème, available at most hardware or home repair stores, to the scratched area. Work in gently with a soft cloth or sponge.
  4. 4 Allow the crème to sit for 15 to 20 minutes. Wipe away with a clean, damp, soft cloth.
  5. 5 Repeat as necessary until the scratch is no longer visible.
Nov 10, 2010 | KitchenAid Microwave Ovens
I need a schematic for an over the range microwave door in order to replace the handle. A samsung model SMH7187STG
Do you have the new handle already? I need a whole new door due to a scratch and will have a new handle from the scratched door that I wont need........
Oct 25, 2009 | Samsung Microwave Ovens
Microwave is scratched
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
Whirlpool Microwave Hood combination Model MH6150XM turned itself on without anyone touching it. The oven and the fan went on. It continued to operate when the microwave door was opened. We unplugged...
Direct spraying of cleaners on the keypad and steam from the cooktop can short the keypad.
Luckily, it dried out. Sometimes it doesn't, and the keypad has to be replaced.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Jun 22, 2009 | Microwave Ovens
My micorwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
More info on such problems:
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Sep 10, 2008 | Samsung MW1030WA Microwave Oven
Scratches on microwave door
We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
Jan 07, 2008 | Viking DMOR205SS Microwave Oven
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
