Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower won't turn over. It's not the fuse. Also it was running good when it shut down.
    President:
  • 3,074 Answers
You can jump it with your car to eliminate the battery, if it is not the battery then you might want to pull back on the lever that engages the blades, it start then . Good Luck Tim
Posted on Nov 14, 2010
My huskee 21 173CC OHV powermore push mower starts then stops. What could be wrong? I changed the spark plug and the air filter.
Cindy, try running with gas cap off , if it runs OK then the caps vent hole is plugged, either try and clean vent hole or replace cap. It could also be a dirty carburetor which would need torn down and cleaned/rebuilt. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why Your Mower Won Start Mower Reviews Consumer Reports
Lawn Mower That Starts then Stalls
Lawn Mower Starts Then Stalls
Engine starts and then shuts down
Jun 25, 2016 | Garden
Gas keeps getting in with oil what do I do riding lawn mower
Happened to my Husky..Your mower is equipped with the EPA positive shutoff electrically operated valve on the bottom of the carb..it is designed to stop overflow of gas from the carb when the float sticks.. however when it fails the gas now flows back through the carb and into the cylinders and eventually filling up the crankcase and cylinders.. In stead of to the ground...You can replace it but eventually it will fail...the easiest and best fix is to put a easy to get to shut off valve between your tank and carb..When ever you shut your mower down for ANY reason turn off that valve before shutting it down..put mine on two years ago and hasn't failed me yet...Just need to remember never shut the mower down with out turning the gas flow off....NEVER....it may not fail but when you least expect it WALA oil in the gas...best is to shut the gas off and let it run for 20 seconds or so then shut the mower down..this assures no gas in the carb system cannot get into the oil...hope this helps pass it along to your friends as all newer motors are required to have them...good luck.
Apr 16, 2015 | Garden
Why do I have no power to mower?
You have a safty switch that is not making good contact trace them all down and make sure they all work, and then you should b ok
Jul 27, 2014 | John Deere Garden
Blade won,t turn
hey john bruce . what type of mower . there could be many reason . there blade clutch there a cable you have to hold down to start the mower could be causing it not to turn or the engine could be seized if so remove the oil ffrom the mower remove the spark plug tie spark plug wire away from any metal . get some :PBblast or trans fliud pour a cap ful down the spark plug hole leave the mower ( if small one vertical for1-2 days if there a blade clutch tie up with shoe lace to handle remove blade or use chnk of wood and big hammer hit the wood to see it blade will move if does try again the allow fliud in spark pug hole to loosen the blind ( understand when that blde may loosen and the mower may run it will smoke badly do not run on fast and after it run and hopefully loosen up change oil and good luck . i been in the lawn maintenance and repair for 43 yrs . if it work you may get a shorter life out of the mower of maybe not bruce
Dec 02, 2013 | Garden
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Lawn mower won't start, looking for help to troubleshoot.
take your lawn mower to whom you bought it from and ask them for help
May 22, 2012 | Husqvarna Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
