Hello. I have a Dell Inspiron 1545. The screen is broke so I use a VGA Cable to attach it to a tv screen so I can see. But this time I tried to turn on my computer and it is not loading at all. It is on though. Before, I had to shut it off by pressing the power button on the keyboard. Maybe that is the problem. Help?
  • 44 Answers
If the battery is good and the power supply is connected and you are not getting any lights on the computer then the problem is that the motherboard is broken and you have to have that fixed by changing the board I do not know if the Dell1545 has a separate supply inside connected to the motherboard
Posted on Nov 14, 2010
How do i switch a dell inspiron with a broken screen to a vga monitor?
Look at the "F" keys. One of them has a drawing of a screen. Press it and your external screen should work, or, plug the external screen in before youboot up. The pc will detect the external scree and switch automatically.
Nov 19, 2013 | Dell Inspiron 1545 Notebook
Can you help with my Dell inspiron 1545 VGA problem?
Laptops use shared RAM memory, it uses part of the main RAM.
If the RAM is faulty or not making proper electrical connection it affects the video.
Reseat the RAM module/s and if this does not fix the problem, remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM.
Apr 01, 2012 | Dell Inspiron 1545 Notebook
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
Replaced screen now the new sreen is really dark
Check the inverter is firmly attached and that you have FIRMLY plugged the vga cable into the back of the screen and the offshoot cable into the other side of the inverter.
Inverter may be faulty also
I'm assuming you set the screen brightness to maximum using the FN and number key?
Jul 29, 2011 | Dell Inspiron 1545 Notebook
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
The screen in my dell inspiron 1545 broke. when i tried to replace it, it stopped working. the old one used to light up and doesn't anymore. I'm not sure if the new screen is the correct one or if...
1. Its very technical thing to replace a screen and you should know the appropriate model of screen.
2. Take it to computer repair shop and get it replaced.
Apr 04, 2011 | Dell Inspiron 1545 Notebook
Trying to set up my dell inspiron pc laptop to my vizio tv with a dynex vga pc monitor cable and not having any luck
Sometimes you have to change the display settings to allow you to use the external VGA plug
1. Go to Control Panel
2. Go to Display
3. Click the settings tab
4. there should be a dropdown tab
5 then you choose the 2nd screen
Try this link as well http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
Mar 30, 2010 | Dell Inspiron 1545 Notebook
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
