Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Cant find a grass catcher bag for this model, rear mount
    Champion:
  • 313 Answers
Give me more info of what type,make & model of the mower's.
Posted on Jun 19, 2008
Troy Bilt self propelled walk behind...grass goes everywhere!!
Mine works,great,take bag off and it will mulch it and look like it's being bagged up.Is your grass knee high?Do you have it low enough?Here's your manual,read the part on grass catcher and see if your doing something wrong,make sure grass door is open.Check your blade to make sure they didn't put it on upside down.The cut part should be facing out. http://pdf.lowes.com/operatingguides/043033566280_oper.pdf
Jul 21, 2017 | Troy Garden
The x300 mower is alway loading up with grass every time I use it In the spring. Is there a better mower for the x300 that won't clog up ?
what do you mean by loading up with grass
it is a walk behind or ride on mower
does it have a rear catcher or big carry bag as on ride on mower
more information would be helpful when you repost with all the details
May 03, 2017 | Garden
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Can't find grass bag
As long as the model number is correct. Sears still carries the bag for this.
Part No. 410693 for $40 us
I found this at Sears parts direct, and yes there is a website.
Jun 17, 2013 | Craftsman Garden
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
Rear mounting grass catcher has space along bottom where all the grass gets out. Yes the side shooter is closed. Yes the top door over the catcher is closed. Yes, it's hooked onto the only place I can...
grass will build up over time on the underside of the deck possibly impairing the flow of the clippings. I use a flat screwdriver to scrape the big clumps of grass off the underside.
Jun 13, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Need agrass catcher for my craftsman riding
If you went to www.searspartsdirect.com, like I did, You found no references to a bag for this mower. It is the same as a Murray rear engine rider and I have not seen a Grass Catcher made for one of them either.
Dec 16, 2009 | Craftsman Garden
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a MTD garden tractor with 3 bag catcher and the shute constantly plugs up. I mow once a week but it's like there isn't enough vaccum to blow the grass into the bags. I have my blades with the bent...
bent part of the blades need to be facing up towards your deck which creates a vacuum and allows a better lift to throw the grass in the bag When bagging blades should be labeled as high lift blades which are designed for bagging . Also which you probably already know its better to bag when the grass is NOT damp.
Hope this helps your issue
Jun 04, 2009 | Mtd Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
65 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
