Question about Dometic Rooftop RV Air Conditioner
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it myself but dont knowmuch about ac units. how hard is it to fix?
  • Dometic Master
  • 6,674 Answers
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Posted on Dec 03, 2010
My trailer roof top a/c is not cooling propeerly
Try regassing it. It may help solve this problem.
Jun 02, 2012 | Coleman Heating & Cooling
I have 2 Coleman roof ac's on my 34' coach that are ducted. The fans work and the compressors come on but the air isn't cold enough to cool the coach. The front unit temp only goes to 70 deg....
Are there any filters? If they are clogged the unit will not work properly and the temp will not drop as much as it should as it cannot absorb the air in the trailer or room.
Aug 02, 2011 | Coleman Mach 15 Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
Water leak
If you remove the air grill for the inside part you will find four screws which when tightened compress the seal gasket under the outside to roof. It may be a case of these screws being somewhat loose.
Apr 12, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
460 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
