Pc shutting down possibly overheating when used
  • Anonymous May 01, 2009
    I have the same problem. No beep on mine, but I didn't think it was the power supply as the PC shuts down, but the power supply stays on, and the motherboard has lights on (i.e. power to it). So I assumed it was the cpu that was overheating. Thank you
  • 859 Answers
You would be correct in thinking your PC's Motherboard would terminate your session from an overheat at your CPU but your Power Supply can do this as well if it is not sufficient to supply your system while under demand or not.
The clue is whether you are hearing beep warning prior to shut down. Those beeps would be the warning built into Windows and the MB both to warn you you are overheating at the CPU. Most MBs are sophisticated enough today to shut you down if you're not around or just do it anyway.
If it is your CPU your fan is probably dirty and the heat sink underneath as well. Just blow those out with canned air and that should solve your problem
If you're not hearing beeps then your Power Supply is weak in one fashion or another not worth going into here because of the many variables.
If your system is rather new you can probably get a tech onsite to have it replaced under warranty. But you will get the same weak power supply and not a better one so, in the meantime you will want to consider getting a larger power supply, in wattage supplied that is. The standard today is to go with a minimum of 700Watts and if you're a gamer with a lot of RAM and hard drives and dual PCIe display adapters yo will want a 1,000 Watt Power Supply.
You can find the model of your choosing at and these are easy enough to replace. I would suggest an Antec model or PC Power and Cooling if you have the bucks. The wiring inside your PC can be something of a pain depending on how big your interior space is. Most of us use tie wraps to bundle power cables and keep the cables tamed as much as possible. If you buy the retail Power Supply vs. the OEM version you will get full instructions. But, in your case you can examine your current interior and even take a photo of it with your cell phone and email it to yourself as a guide in hooking everything up. Just keep the power cord disconnected from the wall until you're done and watch out for elements on your MB that could be bent by your hands and fingers handling the cords.
Posted on Jun 19, 2008
  • Glenn Rogers
    Glenn Rogers Jun 21, 2008
    Thank you for rating.
    I am curious thou what are you hearing from your PC if anything when your machine attempts t reboot?
    Just how old is your system?
    Have you solved this problem and or do you want to continue to troubleshoot this using our email post system?
HP Pavillion tx2-135dx laptop overheats
hi.Fan Always Runs Or Laptop Overheats And Shuts Itself Off
Warning! Before Disassembling Laptop always unplug power and remove the battery.
Laptops that shut down without warning are often experiencing overheating issues. Overheating may be a symptom of age, of clogged ventilation or impending failure, but it can also result from simply using the laptop in a bad location. Before you try to take the laptop apart to look for problems, it pays to patiently troubleshoot the symptoms and see if an easy fix is possible. I wrote The Laptop Repair Workbook to teach basic laptop technology and troubleshooting to regular people and techs in training. The overheating flowchart below is one of twelve flowcharts in the book.wfwmoavismn7iaaaaasuvork5cyii=
May 09, 2014 | HP Pavilion Computers & Internet
I star the computer and shut down then go on and shut down
Possible overheating issue, check to make sure CPU fan is coming on and also resit memory and hard drive just to be safe
Feb 27, 2014 | Acer Computers & Internet
Custom build PC shuts down by itself
you are overheating.did you use enough termic paste ? your computer shuts down for so it not breaks the to at allways as few startup programs as possible.and invest in a new PSU.
May 28, 2013 | Abit KT7A Motherboard
Dell d610 shuts down while playing games
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
Mar 31, 2012 | Dell Latitude D610 Laptop Computer -...
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
I have a Toshiba P15S420 laptop and after years of using it starts to shut down after some time powered on. It works pretty wel until it shuts down. Do you have any ideia what it could be...
overheating issue no doubt have it cleaned and inspected for signs of overheating possibly could be other failures but its a good place to start
Dec 21, 2010 | Toshiba Satellite P15-S420 Notebook
Computer shuts down unexpectedly
Your Computer is overheating and is shutting down to protect it's self from damage. Your Computer needs to be serviced/cleaned of any and all dust. Pay special attention to the CPU cooler and graphics card. Install as many fans as possible.
Nov 26, 2010 | E-Machines eMachines Desktop PC
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
Dell shut down automaticly can someone help
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Dec 24, 2008 | Dell Inspiron 6000 Notebook
Possible overheating problem for Acer Aspire mini L100
I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
Sep 26, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
