TV won't come on no noise at all is there a fuse in the back under the cover
Tv is a RCA Model # P46813BL have had it on broadband conection with a digital box. have had the volum up high for elderly Mother, so when it was off it still made some noise. Not now is it a posibility that a fuse blew? I will look in the back tomorow hope to here from you soon too. Thanks Alfred
  • honda3 Jun 19, 2008
    I am going to get a 5 amp fuse and try it because my tester showed .78 on the continuty/ohms setting not 0 like you said it should. thanks I will let you know if it works soon. Alfred
  • 1,139 Answers
That might be the problem, however what I would suggest is that you unplug the TV open the back look for a fuse remove the fuse (if you can, it might be soldered in) and then with an ohmmeter set to 1xR measure the resistance it should be 0 ohms. If it is not then that is the problem. If the meter reads 0 ohms then you will have to put the fuse back in and at this point I would suggest that you either replace the TV or take it to a repair shop.
I hope this helps
Thank you,
Posted on Jun 19, 2008
  • Henry McKelvey
    Henry McKelvey Jun 20, 2008
    Hello Honda3,
    It looks like that fuse might be good because it is under 1 ohm. which shows that the fuse is good. No reading or ------ would have meant the fuse was bad. So it looks like the fuse is good. Now this means that you will have to have the TV set looked at by a shop because you might be having a problem with your Horizontal output circuit because it is used to derive some of your lower voltages from.
I have a RCA Home Theatre TV Model# P46813BL and we are having trouble congiguring the screen. We had a fuse blow, and have replaced it, but now our picture is off. We have used the TV remote to pull up...
If the color are separated then you need a new convergence board, or have it repair. If the controls are not working correctly then the processor could have some garbage in it, do to a small power surge, and you will need to leave the set unplug from the wall for 40Min. and it will reset back to normal.
Mar 08, 2011 | RCA P46924 46" Rear Projection Television
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
Rca p46813bl convergence problem bowed in the
OK., I know this set very well. It almost never has a convergence problem.
With the set unplugged, remove the back cover--there is a small circuit board mounted ABOVE the main boards--it is about 10 inches wide and 4 inches tall---On the far right side of it are several DIODES---two are much larger then the rest--what usually happens is one of the large diodes is shorted--5 dollar part---the board only has a few plugs and 4 screws that hold it in---easy to remove--check all the diodes(the two large ones first)
If either of the large diodes read like a fuse you FOUND YOUR TROUBLE.
LET me know if you need ANY help or Advice--I am here to help people---I have seen several sets identical to yours with the problem you describe.
Regards, SD TECH
Oct 06, 2009 | RCA P46924 46" Rear Projection Television
RCA HDTV Model # HD52W59
I hope it is still under warranty,cause you need to either fix the problem with a A/V repair guy or return it and get your money back.
Don't fool around with it.
Nov 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA TV model # P46731AT
Why is my picture more blue then red bulbs are working on RCA .....P46731AT
Oct 29, 2008 | Televison & Video
No Power
Try removing the Green CRt PC voard that is on the bottom of the green Picture tube which is the center one. Then replace the fuse and see if your set powers up if it does you need a new gree tube. Just be sure the crt board doesnt touch anything while you try it. then let me know what happened, if you need a tube they arent available new any longer but I have a source for good used picture tubes,
May 22, 2008 | RCA P46812BL 46" Rear Projection...
Won't turn on
il ne s'allume pas et il y a un regulateur dont je peux pas voir son numero
Apr 30, 2008 | RCA F19430 19" TV
Tv will not power on
1)Please verify service # from back of set...Very important..
2)Probable bad ground solder connections...tuner circuit
3)probable bad flyback transformer and / or horiz o/p xistor
Dec 21, 2007 | RCA F31672ET TV
RCA p46813BL with no picture but good sound
The good news is your set has a picture therefore is not an output transistor,the problem your set has is a signal processing problem,no video of any source is being processed,is just a different kind of problem and for that you will need the assistance of a servicer to diagnose,try taping where the cables conect to the tv if the set reacts the loose conection is close to that imput panel but if it does not be safe and call for help.
Oct 01, 2006 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
