Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
When I got the machine I folded the control panel tray to it's out position. I have to return the machine & it is being replaced by a new one. I have to send back the defective printer. How do I fold the control panel back into the machine for shipping back to Lexmark.
How do I fold the control panel back into the machine for shipping back to Lexmark. 400 series
Posted on Mar 06, 2011
The thread guide of my Elna Lotus has fallen out - how do I put it back?
Is this one of the Swiss metal Lotus models with the fold down flaps and a metal thread eye which sits under the lid of the accessory tray? If so, its pretty simple to unscrew three or four screws which hold down the accessory tray and flap on top of the machine and then replace the metal thread eye back into position, there is one screw which holds a plate on the underside to keep it in place from memory.
Jan 24, 2015 | Elna Sewing Machines
The tray won't close
Look for an obstruction or incorrect assembly of the tray or debris containers on the tray. On some models if the brewing mechanism has not returned to the start position you cannot replace the tray. Such a shame you were unable to supply any information to help us to help you.
Sep 27, 2014 | Coffee Makers & Espresso Machines
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
What are the benefits of an automatic paper folder?
These are great because you can choose what type of fold you want. You can choose between all different folds on the control panel. Lots of folding typesare already programmed into the machine. These machines are very efficient and can fold 18000 letters/hour.
Jan 17, 2013 | Office Equipment & Supplies
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
2004 ford expedition eddie bower
For the rear window, just need adjuts the both slightly...
Check the next procedure to Power Mirrors...
Diagnosis & Testing
The exterior mirror control switch receives power through circuit SBP12 (GN/RD) and ground through circuit GD143 (BK/VT). The exterior mirror control switch uses circuit CPM23 (GY) as the common circuit for both exterior mirror up/down and right/left movement.
  1. Possible Causes:
    Fuse 12 (7.5A) (SJB) An open in circuits CPM23 (GY), SBP12 (GN/RD) or GD143 (BK/VT A short to ground in circuit CPM23 (GY) A short to voltage in circuit CPM23 (GY) Exterior mirror control switch.
  2. Checking the voltage at the mirror switch:
    Key in OFF position. Disconnect: Exterior Mirror Control Switch C527. Key in ON position. Measure the voltage between ground and exterior mirror control switch C527-1, circuit SBP12 (GN/RD). Voltage should be greater than 10 volts.
  3. If voltage is greater than 10 volts, check that fuse 12 (7.5A) is OK. If OK, REPAIR circuit SBP12 (GN/RD) for an open.
Exterior Mirror Motor Synchronization
NOTE This procedure must be performed any time the power folding mirrors are manually folded in or out, or if the position of the mirror case has been moved without using the mirror control switch.
NOTE If the power folding mirrors are folded or unfolded continuously (6 to 10 cycles), the power lockout feature will disable the system for 2 minutes to prevent damage to the power fold motors. After 2 minutes have elapsed, normal operation will resume.
  1. Set the mirror control switch to the CENTER position.
  2. Use the mirror control switch (press rearward) to automatically cycle the power folding mirrors in and out 4 times.
  3. When an audible popping sound is heard, the power folding mirror motors are synchronized.
    NOTE It may be necessary to cycle the power folding mirrors in or out up to 4 times before they are synchronized.
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the precautions section.
    NOTE If equipped with power folding mirrors, they must be synchronized any time the mirrors have been folded or unfolded without using the mirror control switch. Refer to synchronization procedure.
  2. Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
    CAUTION Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
  3. Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
  4. Carefully pull the top edge of the glass away from the exterior mirror housing.
    0996b43f802029e0.jpg Fig. Mirror Glass removal shown
  5. If equipped, disconnect the heated mirror electrical connectors and remove the glass.
  6. Remove the 3 exterior mirror motor screws and exterior mirror motor.
  7. Disconnect the electrical connectors.
  8. To install, reverse the removal procedure.
Switch
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors. Navigator Trim Panel Removal
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
  10. Depress the locking tabs and remove the exterior mirror control switch.
  11. Remove the exterior mirror control switch.
If you dont want waiting more time for the Owners Manual, can check here this choice 2004-Ford-Expedition-Owners-Manual
Hope this help.
Apr 23, 2010 | 2004 Ford Expedition
Saturn vue 2007, rear folding seat will not return to proper position due to seat belt being locked up.
They have a problem with the seatbelt retractor getting jammed up causing the belt to jam & not let the rear seat fold back up.The easiest way to get the seat back up is to cut the seatbelt & fold up the seat.Then the rear seat needs to be disassembled to gain access to the seatbelt retractor assy which has the seat belt made on.Hopefully it's still under warranty or Ext. warranty.hope this helps
May 17, 2009 | 2007 Saturn VUE FWD 4
Kitchenaid proline espresso maker, model KPES100NP 2. Espresso boiler frequently discharges outside of unit instead of into removable tray.
I took out the water tank. Found a return discharge hole in the middle of the over hanging brewer body. It was in the middle of the deep indention.I placed a self adhesive folded plastic door weather stripping between the discharge hole and the brewer body. I used about 1 and 1/2 inches of the stripping. I made sure the fold was angled back away from the brewer. That seemed to force the water back into the water tank and my counter has stayed dry. I still get quite a bit of water under the catch tray, but if i clean it one every 20 pulls it has never over flowed.
Jul 19, 2008 | KitchenAid PRO LINE KPES100PM Espresso...
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
516 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
