Xerox docucolor 250 error code 042-326
What exactly is causing this error to appear Scott @ info@promedia.la
  • 1 more comment
  • Anonymous Dec 21, 2008
    xerox docucolor 250 error code 042-326
  • Anonymous Mar 12, 2009
    042-326 error codes docucolor 250
  • Elvis Osei Ampadu
    Elvis Osei Ampadu Aug 29, 2012
    I usedocucolor 250 and this error code 042-326 has been a torn in my flesh, a technician has come to service it again and again. i have changed the belt yet it is disturbing me. who can help?
Belt Failure turn the mach. off and un plug for 20 to 30 seconds then turn back on if this dosent sole you need to call a tech to replace the main belt
Posted on May 30, 2009
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Fault code 127-337
Xerox dc240 error code 127-337 problem solustion
Aug 06, 2012 | Xerox DocuColor 240 242 250 252 260 Black...
We have a docucolor 250 and have the error code 016-311. I want to know what it´s means.
May just have a bad cable connection from the scanner to the processor or the scan lamp is bad.
Feb 12, 2010 | Xerox DocuColor 240 All-In-One Laser...
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Xerox DC12 system failure: code 10-361
I have found the Heating Tube 520 is dead, so the Roll doesn't hot enough. This problem was solved simply - by replacing the Tube...
Feb 11, 2009 | Xerox DocuColor 12 Color Copier
Erox dc 12 error 9-342
In Spanish
Quita la tapa de el drawer
Obseva la media lunita de el 2nd BTR Black & yellow Cheat el sw de la puerta Si no hace el intento de girar . Quita la tapa posterior y observa si gira el motor principal y el motor de el cilindro si no giran tienes un problema en la AC driver 5Volts o en los 24 volts verifica tambien los fuses de la PWB de interconexion y de la Ac driver suerte
Nov 12, 2008 | Xerox DocuColor 12 Printer
Error code 10-162 docucolor 12
I honestly can't find that code in the documentation or I would have sent it to you.
Apr 03, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12
como puedo limpiar el area caliente de la maquina ya que no se como desarmarla me pueden ayudar gracias
Mar 05, 2008 | Xerox DocuColor 12 Printer
4,605 people viewed this question
jasbo
jasbo
