Question about Acer Aspire 5735 Notebook
What button do you push to enter vga, monitor mode
  • 355 Answers
I found THIS video that may help. On some other Manufacturer laptops you use the Function key along with F7 and other models use FN+F4. If it is a Function Key it will have a small picture of a monitor on the key, search your function keys if the video does not help.
HERE is another video that may help also
Posted on Nov 14, 2010
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
EVERYTHING on monitor is upside down
login in vga mode and change vga resolution settings. For open vga mode restart your computer press "F8" button it shows some modes in that select vga mode and press enter. then change vga resolution in display properties> settings change to low resolution and restart your system
Jul 07, 2010 | Dell Dimension 4700 PC Desktop
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
When i start up my computer it says on the monitor out of frequency
when You start the monitor please press F8 button of keyboard upto dos screen come and select a option that Enable VGA Mode and press Enter.Might be problem will resolve.login through administrator and set the display setting as 1024*768 .If again problem comes that out of frequency ,then restart the system and press F8 and Enable VGA Mode and login and re-install the Graphics driver again.If issue not resolved then problem with VGA port in CPU or VGA Cable not supporting gt it replaced.
Nov 13, 2009 | LG Studioworks 440SI 14" CRT Monitor
I HAD REPLACED THE GRAPHIC CARD, NOW WHEN I SWITCH ON THE COMPUTER ALL I SEE IS SIGNALS OUT OF RANGE. IM RUNNING W/XP.& A HP PAV. F 1523
Switch on the computer. Just as the BIOS messages or full screen logo is about to end, press F8 several times. Then you will see the Startup Menu for Windows XP. It will look like the following.
Safe mode Safe mode with command prompt Safe mode with ... .......................... ..........................
Check whether you have a option as 'Enable VGA mode'. If you see this, select it with arrow keys and press enter. You may have to press enter again.
(Since the computer was not shut down properly the last time you switched it on, you might see this menu when you switch on the computer. So simply select 'Enable VGA mode' )
The problem is you have a new VGA card and somewhat old monitor. The current Video Refresh Rate of the VGA is not supported by your monitor.
So once you start the computer in VGA mode, go to Display Properties, select 'Settings' tab (1), Click 'Advanced' button (2), Select 'Monitor' tab (3), Select the minimum value from the list (4) and click OK buttons(5).
Good luck! If you find this information useful, please give me a good rating.
Jul 13, 2009 | HP Pavilion F1523 15" LCD Monitor
Error of resolution
when u power up the computer press F8 key then enter in enable vga mode then go to disaply properteis then set display resolution to 1024*768
then apply and ok.
Mar 23, 2009 | Computers & Internet
I have an asus mother board with athlon64 3800+ cpu. I have two dual head nvidia geforce 6600 vid cards ea. w/ 1 pcie and 1 pci output to sli and vga, respectively. I barely know what I'm talking about...
sounds like your computer is going into standby or sleep mode. Does hitting enter on the keyboard turn it back on? Does pressing the power button turn it back on? One of those should do it.
You can change it so it does not do this, In windows xp you can goto power options in the control panel, and change system standby to 'never'. Not sure in vista probably about the same thing.
If this doesn't help then maybe you have a hardware problem.
- Dave
Dec 11, 2008 | Computers & Internet
My LCD monitor is going into power saving mode
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Sep 30, 2008 | LG L1915S 19" LCD Monitor
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Acer Aspire 5735 Notebook Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
