Question about KitchenAid KEBC107 Electric Single Oven
Error code f3e2 - KitchenAid KEBC107 Electric Single Oven
  • KitchenAid Master
  • 1,711 Answers
F3 - E2 Oven temperature is too high (Cook mode)
Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes
Posted on May 05, 2011
F3e2 error
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Kitchen Aid f3e2
Note:
This error code applies to all F3-E... faults.
Good luck.
Jul 21, 2011 | Ovens
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
Had an error code F3E2 show up on the screen
F3-E2 Oven over heat. Replace Sensor
0ae81cf.jpgOven sensor should measure around 1100 ohms.
Oven sensors should not be grounded. Continuity from frame to either sensor wire is a bad sensor.
Got popcorn? Heres a movie:
Oct 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
When using the oven I get an error message of F3E2. I was told to turn the power off at the breaker box by a Wirlpool associate and that should fix the problem, which it did but now its not heating to the...
A reset switch is what he is talking about. Turn power off at breaker for one minute if this does not rectify problem have a service tech come out. A local appliance guy is usually the cheapest and best route to take as the brand name guys are usually few and far between.
Oct 11, 2010 | Ovens
When I use my oven after it is on awhile it says F3E2 and burns my food. What does this mean?
Hi
Thanks for using FixYa. F3-E2 error means that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Ovens
Trying to clean oven get code F3E2
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 07, 2010 | KitchenAid Architect Series KEBC107KSS...
Oven indicator lights flashing F3E2, what does that mean?
look behind thecontrol panal and find the wire diagrame,you may have to remove the back panal.un plug unit first.on the diagrame it has a place were it tell's you what f3e2 mean's.
Nov 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
KitchenAid KEBC107 Electric Single Oven Logo
624 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
