My sharp TV (lc-52d65u) will not turn on, just the power/OPC green light are blinking
  • 4 more comments
  • dothho1 Nov 15, 2010
    Hello Taran 2005,
    As soon as I plug the power on, the relay at the back will click and the power (green) light on and stay on, then the relay at the back will click on/off for every 1 minute , after on/off for three time the OPC will blink one and the power light will blink three time and so on untill I have the power unplug.
    Thank-you
    Hello Taran 2005,
    I unplug all cable to the main boad , plug in power nothing happen the relay won't click , would it be posible with the software update , I did the update this morning before go to church, anyway can I check the current or reload the old sofware ???
    Thanks,
    Hi Taran 2005,
    Yes, it happen after update the firmware LAKEA310.UVP
    Thank-you,
    Thank-you,Thank-you very-much.......
    I did the factory reset and it work, I am glad I found the "FixYa" and the expert like you,
    THANK-YOU EVER SO MUCH.....
    Thank-you ever so much, The solution very helpful, the problem fixed..
  • dothho1 Nov 16, 2010
    Hello Taran 2005,
    How are you today? I wake-up in the morning turn on the TV. to watch the weather network before go to work , but the TV doesn't work , same think happen" the power/opc light are blinking and the TV worn't turn on" , I had to do the factory reset procedure to get it to turn on. is there any solution to get rid of that bug ???
    Thank-you,
  • 10,515 Answers
Can you please give us some more information so I can better answer your questions.
-Those lights should be blinking a code, can you determine it for me?
For example - OPC blinks 3 times and then power and OPC blink twice and so on.....
Thanks!!
Posted on Nov 14, 2010
  • 2 more comments
  • taran_2005
    taran_2005 Nov 15, 2010
    Thanks for your response!!
    I had a discussion with other experts regarding this problem.Simply 90%of the time its powerboard or mainboard them flashing OPC and
    power lights are not accurate for which board is at fault.There is a complete technical bulletin that was issued.
    Now, to explore which would is at fault, lets take it one by one :-
    1. Power board - This seems to be a more probable cause. Clicking or relay noise is mostly due to defective power supply board. Few caps on it may be bulged/leaked/swelled and unable to transfer the current. As board is receiving the current and the caps are unable to complete transfer it, causing this. Moreover, this model has been in limelight for caps failure.
    2. Mainboard - If the power board is fine, then we need to check this. There are many board level component that needs to be taken care of on this board.
    There are reports of LCD panel being failed on this model.However, i would not proceed to any speculation without checking the main causes.
    Let me know,once done.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    Is this an issue after firmware upgrade?
    Which software was used for this model?
    is it LAKEVA04.USB
    LAKEM304.BIN???
    DUNTKE716FM02
    DUNTKE716FM01S??
    Let me know,so that we could proceed.
    Hope i helped you.
  • taran_2005
    Try a factory reset procedure :-
    - Unplug the TV and count to 10 slowly.
    - Hold down the power button on the TV (not the remote.)
    - Plug in the TV while holding power button.
    - Count to 10 and release the power button.
    - Turn it on and hope for the best.
    Hope i helped you.
  • taran_2005
    I glad that it worked ......
    Do accept the solution so that i would be compensated for my time.
    Thanks and Regads
    taran_2005
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Brand new sharp aquos LC-52D65U no picture
Sounds like a over heating issue, try unplugging the unit and leave it for an hour , before you reboot. make sure there is some kind of ventilation in place . Also double check your connections very important.
Apr 12, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
599 people viewed this question
Top Televison & Video Experts
Electro Med Services...
