Question about Star Logic Monitor
I am trying to use the DVI setting on my starlogic mj9abk, but it will not let me change the resolution, nor does it give me the option. can someone help me learn how to change the resolution? thanks!
2 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Posted on Mar 21, 2009
PC DVI-D to Mitsubshi DVI-I no signal
have you set the dvi out to 720i as any higher the tv will not read it as a signal. you will need to verify it in properties windows will set it at 1080i. you need to change it.
Mar 08, 2014 | Mitsubishi Televison & Video
I have a custom built computer with dual NVIDIA GeForce 8400 GS - 512MB - 16X PCI Express. Until recently, I had two Eizo L565 monitors. I had one connected by DVI-D and the other by D-Sub. I acquired a...
You have to use the dvi-d cables on both video card in order to get the higher resolutions on both screens. also the nvidia control panel must be set up the right way so that both screens receive the higher resolution.. there should be a selection for panning across both screens, and another for selecting apps on 1 screen and main os on the other. try changing those settings around, more than likely that is the reason that it's going at a lower resolution.
Dec 17, 2010 | Computers & Internet
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
I have a Starlogic LCD monitor
you have definitely chosen a higher resolution than what your model of monitor could support , if you have a spare monitor please conenct change to regular 1024/768 resolution save it restart system and plug back this monitor and it should work , also you can try starting you comp on safemode and set the above specified resolution and try , do let me know what happens.
rgds
dil
Jul 30, 2009 | Computers & Internet
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
Feb 05, 2009 | Star Logic 17" LCD Monitor
Changing Resolution
there is a chance that your computer onboard video does not support a higher setting. what operating system do you have, using onboard video or a video card would assist me in giving you advice.
Robert
Aug 27, 2008 | Star Logic 17" LCD Monitor
Problem connecting DVI input of TV to DVI-D output of video card
For error code 0122, Don't play the movie or load your movie program until you have the resolution you want and have it set to display only on the hdtv . You do this by going to control panel, selecting "adjust common used mobility settings", and then clicking on "connect display. A pop-up will come up and give you the option to display only on the external display. Pick that. The thing that sucks is if you have the display set to 1920 x 1080, you can't see everything on your desktop when trying to view it on the tv.
May 17, 2008 | Acer AL2671W 26 in. LCD Television
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic  Monitor Logo
88 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
