Question about View and View Technologies VNV AquaView 17XP 17 in. Flat Panel LCD Monitor
I am not computer saavy, but I picked up a View and View Tech, TFT LCD monitor (model 17XP)at a garage sale. It didn't have the power cord and I am wondering where I may find a replacement power cord. The monitor says DC 12V/4.0A. Also, would I need a driver?
  • 11,361 Answers
Http://www.12vadapters.com/ Higher current rating is OK but not the voltage.
If you run windows 7 you will not have the driver for it since its too old, XP should be OK without the driver.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 14, 2010
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
I have A VNV Aquaview 17xp monitor,when I turned it on the power button lit up orange,the screen is black,is the transformer bad,can I buy parts to fix this,or do I need to throw it in the trash. and now...
Take a look inside and also read about bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 26, 2010 | View and View Technologies VNV AquaView...
Damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
Jun 13, 2010 | SVA-USA 9005B (Black) Monitor
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Soyo TFT 19" LCD Monitor
Where do i find a power plug for an older model
how about the plug size, normally, it comes with 2.0/2.5mm?? it looks like 15" lcd monitor and i think it is compatible with 12V 4.0~5.0A.
Mar 22, 2010 | Samsung SyncMaster 570 V (Ivory) 15 in....
The Dell E17Fpf 17" TFT LCD Monitor power-on very dark with the left side of the screen darker than the right. After on for about a minute, the brightness comes up to near normal brightness. Please...
Your backlight inverter is about to go out. There are 2 small parts that need to be replaced. Check our web site at: www.ccl-la.com, we have a step by step repair guide to that model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 21, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
No sign of power
have the switching power supply checked or might need a replacement
Aug 10, 2009 | Gateway 19" Flat Panel LCD Monitor
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Input not supported
Do you get anything on the screen when you first turn on your computer?
If you do the windows resolution somehow got set to high for the screen to handle. To fix this press the F8 key a couple times after the BIOS splash screen goes away ( The screen that has HP or DELL, etc on it). If done at the right time it will bring you to a menu that has several options including safe mode. You'll want to pick " Enable VGA mode." From there it will start to load Windows, but everything on the screen will be large. Once windows is fully loaded find a empty spot on your desktop and right click. From the menu that pops up please select Properties. It will open up a box that says "Display Properties." Click the tab that says Settings. On this tab move the resolution slider to right right a click or two to make the monitor normal size and click apply.
Nov 14, 2007 | View and View Technologies VNV AquaView...
View and View Technologies VNV AquaView 17XP 17 in. Flat Panel LCD Monitor Logo
55 people viewed this question
Top View and View Technologies Computers & Internet Experts
David Payne
David Payne
Are you a View and View Technologies Computer and Internet Expert? Answer questions, earn points and help others
