Question about Samsung SyncMaster 920NW Monitor
This Monitor will not trun on. Can you help me?
  • 11,361 Answers
If you look at my albums, you will see common problem with the monitors: bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 14, 2010
Going hp monitor sleep
check settings in the menu. Usally off timer is set either to shut off after s et amont of time or is just set to on. Trun setting to off and no more sleep.
Jan 31, 2014 | HP W1707 LCD Monitor
Gateway laptop stopped picking up signal from tv monitor. how do I fix problem?
maybe it change screen resolution! try press press auto adjust from the monitor!
Feb 02, 2013 | Gateway CX210X Notebook
LCD Screen blank
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Acer AL2416WBSD 24" Monitor
Noise from back of monitor. sounds liek
yes that is problem of EHT (the biggest part on the pcb) it creats 18000vdc.when it is faulty or leackage it sparks replace it the problem will be solved
Apr 11, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
When I booth it says 'power save' and turn black
This is not a problem with the monitor, but with the VGA card. Replace it and check.
Sep 02, 2009 | LG L1915S 19" LCD Monitor
Bought new desktop but key board and monitor is not working.?
Did you plug the keyboaed & mouse in befor or after you trun on the PC?
Jun 20, 2009 | HP Computers & Internet
No signal detected
Check all of your cables - VGA / DVI mainly in the back of the monitor and the back of the PC.
Jun 09, 2009 | BenQ FP737S-D 17" LCD Monitor
Sound is not loud
buy separate speakers there are issues with lcd monitor speakers not being loud or powerful enough.
Sorry, but separate speakers are the easiest solution
Nov 26, 2008 | Proview PL926WBi 19" LCD Monitor
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Samsung SyncMaster 920NW Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
