Question about E-Machines eMachines Desktop PC
If sitting idol for awhile, the screen will no longer come up
  • 1,179 Answers
Your computer is going into sleep or hibernation mode, have you tryed double clicking with the mouse while in this state. Or if your keyboard has a wake button then press this. Also try using the esc key located on the top right hand side on the screen. Hitting the Enter key can also bring it back to life.
damnor01
Posted on Nov 15, 2010
91 ninja carb/throdel problems
your bike has too less gasoline. check the filter inside your tank.
check if the pipe for petrol is not snapped off.
maybe your carburators are dirty. undo them and clean the float lever and its needle valves.
and check the idle jet and all the other jets
Jul 04, 2013 | Motorcycles
94 camaro v6 engine and the idol runs at 2000 rpms, runs even higher if heater switch is turned on. shop cant figure out issue any ideas?
Not much of a repair shop
Use the codes & reference material to diagnose
the problem
No reason a repair shop can't do that
Leave it there until they drive it & the light comes on
They have a scan tool & have to use it on a road trip
& record the data
Mar 07, 2013 | 1994 Chevrolet Camaro
Alarm is going off and keypad dont work, I disconnected the battery and let it sit for awhile,but the alarm still goes off when reconnected. Do I need to let it sit longer to reset,or is there something...
if you have the original key, go to the driver's door key hole and lock and unlock the door. Do it several times until the alarm goes off. Also you can replace the key pad lock battery.
Aug 10, 2011 | 1998 Mitsubishi Diamante
I havent run my car in awhile and I noticed that when I start the car and after its starts warming up it has a ticking noise when it is idoling. I figured its the lifters cause it hasnt been started all...
If the ticking is a constant ticking, it is most likely the lifters. The lifters in these engines are hydraulic and and must pump up with the oil pressure. Once the oil warms up and become thinner, the ticking will become constant due to the lower hydraulic pressure of the thinned out oil. As far as the moisture from the exhaust, this is also normal of a vehicle that has not been started in a long time as the condensation that builds up in the exhaust system must heat up to a point where all of the moisture burns off. The longer it sits, the more moisture will build up in the system requiring longer times to burn off. If after a few days of running the moisture does not burn off then I would get it checked out by a certified mechanic.
Jan 02, 2010 | 2004 Chrysler Sebring
My idol sits around 100-300 RPM
your idle should be around 750 to 850 in park or neutral
i don't know how it even runs at the rpm you listed.
your vehicle should have a tps sensor
"throttle positioning sensor" you might have to have it reset
Nov 21, 2009 | 1995 Chevrolet K1500
Samsung monitor 19
Check your vga cable does it fix properly.
Apr 20, 2008 | Computers & Internet
IBM x40 LAPTOP
go to IBM web site and down load and install all your drivers, try to get any upgrades this will probably fix your problem. make sure you get the chip set drivers for sure, and the last thing you want to try is a bios flash. you could even find the ide drivers. get all that you can.
Feb 18, 2008 | IBM (03R0308) for Netvista X40 Motherboard
E-Machines eMachines Desktop PC Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
