Question about Lincoln Ranger 250 Gxt Welder Generator K23824
Engine just started blowing smoke. I checked the oil and there was gas with the oil. The welder still starts and runs but there is gas in the oil. What is causing the gas to mix in with the oil?
  • 407 Answers
Looks like you blew off a gasket, try not to run it and send it to an authorized service mechanic.
Posted on Jan 13, 2011
1998 buick lesabre wont start. had a new thermostat installed last week as heater was blowing cold air. mechanic added anti freeze, car was running fine and blowing hot air. today the check engine light...
Sounds like you have water in the oil which means you could have a blown head gasket. Can you tell what got in the oil. Is it antifreeze or gas. If gas you probably have a injector sticking open.
Jun 23, 2017 | Buick LeSabre Cars & Trucks
My Craftsman 5.5 hp 14" rear tine tiller starts but doesn't run for long. It blows black smoke and quits. The gas is new and the oil is good.
Black smoke looks like it's burning too much oil. If it is a 2 stroke engine try a lower ratio of 2 stroke oil to gasoline mixture. Make sure you are using 2 stroke oil!
If it's a 4 stroke engine find out why and or how the oil is getting burned.
Sep 10, 2013 | Garden
Engine trouble
ooooo wellll your oil rings on your pistons are proablly shot as for the gas ist proabbly the fuel pump but first i would check the fuel injectors and the fuel rail also check the compresson on your fuel system beacuse when it start blowing black smoke then basicly your motor needs to be rebuilded
Sep 09, 2012 | 2002 Dodge Grand Caravan
White smoke billowing from front of mower
is the smoke from the exhaust?or just the front of the engine look for a oil leak from the head gasket
Apr 30, 2012 | Garden
Have a toro self propelled. The engine cuts off as soon as it starts and prior to that it was blowing white smoke. It looks like there may be oil leaking under the exhaust, but can't tell where i
It could be that gas is filling the carb because the needle is stuck open. The excess can drain into the engine oil. If you check the oil and it's overfilled and runny, then you need to overhaul the carb and change the oil.
Oct 10, 2017 | Garden
I have a 14.5 HP Intek OHV model 287707 that started blowing gray smoke out of the exhaust after running a couple minutes, then it dies but starts right up again. Also, the oil smells like gas. No...
Yes it is a carburetor problem. The float and needle are stuck open and it is flooding fuel into the crankcase. That is why your oil smells like gas and you have gray smoke. I will bet that it is hard to determine the exact oil level on the dipstick.
First, do not run the engine until corrected or you risk engine damage. The fuel in the oil acts like a thinner destroying the lubrication properties of the oil.
Second, take the carburetor off and clean/rebuild it. When you are satisfied with the carburetor, including the operation of the float and needle, reinstall.
Third, change the oil, for the reason stated in the first.
Fourth, with fuel in tank, note level to make sure not changing by draining through the carburetor.
Fifth, remove the spark plug and turn the engine over a few times to get oil back to the surfaces that need lubricated on startup. Reinstall spark plug
Sixth, check fuel tank level for drop, if no drop, Try starting the engine.
I hope this helps you get it going.
Aug 12, 2011 | Garden
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
I have a 1998 chevy 2500 4x4 6.5 diesel pu.truck starts and seems to run normal ,maybe a little loud, i heard chevy diesels this year are louder than fords etc. blows a little white smoke at startup some...
the head gaskets are blown you can believe that anytime on any engine gas or deisel that you get oil in the radiator and there water/ antifreeze in the oil pan the gaskets and or cylinder heads are bad
Jan 20, 2010 | Chevrolet 2500 Cars & Trucks
Lincoln Ranger 250 Gxt Welder Generator K23824 Logo
123 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
