Question about Nintendo Video Game Consoles & Games
My Wii will not turn on since we played it last.
  • 10,515 Answers
First of all please make sure that all connections are tight and proper.
Following are few more suggestions for you.
1. Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2. (Did you use unlicensed products!) Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see below).
3. Check all accessories, licensed or not, for phsyical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter (see below).
4. Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
5. Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
6. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
7. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet. Click here for detailed instructions.
8. Once plugged in, check the power light on the Power button to see if the system is receiving power.
If this fails, try resetting the AC adapter.
1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Check to see if the power light on the Power button comes on.
o If the system works, plug ONE accessory into your system starting with the Sensor Bar, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (Sensor Bar, GameDisc, Nintendo GameCube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
If all this doesnt help then You will have to get it repaired.
If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Wii console or A/C Adapter) needs repair, please call wii Consumer Service Department at 1-800-255-3700 to discuss available options.
if its under warranty then you should definitely send it for repair..
but if its not then I would recommend opening it up.
Use lightly compressed air to clean out and look for loose connections...
I hope it works out for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
My nintendo wii will not play wii games, but my wii will play gamecube games. Every time I play a wii game the error message keep coming up
1. go to the wii settings.
2. go to the last page.
3. chose "wii system memory format"
this should put the wii back to factory settings, and make the wii games work again.
Jul 01, 2011 | Nintendo Wii Console
My Wii console will turn on, but no signal is received at the TV. The console powers up, you can load and eject discs into it but nothing comes up on the TV. I tried switching TV's and it still didn't...
If you switched tvs and no help than that tells you that the cable that hooks the wii to the tv is probably bad try a new component video or rca cable whichever you are using
Apr 17, 2011 | Nintendo Wii Console
GH Metallica will not play.
u may have overused the disk on ur wii :()
Jun 15, 2009 | Nintendo Wii Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
Wii:disc stuck and wont turn on
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Mar 04, 2009 | Nintendo Wii Console
Three games on wii play won't won't work
This is actually the "Wii Play" game. You must unlock each game by successfully completing the previous game. In this case, I believe that you must play, and finish, Billiards or Laser Hockey to unlock Fishing, then complete Fishing to play Charge!, and so on.
Good luck, and enjoy the games!
Feb 11, 2009 | Nintendo Wii Sports for Wii
Constint blue light
It means WiiConnect24 is on and you have a message. To turn off WiiConnect24 when you are finished playing the Wii, press and hold the power button until the light truns to red.
Jan 30, 2009 | Nintendo Wii Console
We are not able to access all the games on Wii Play??
my lad has the wii sports and with that you have to be proficient at some games to unlock the rest in turn as you improve
Jan 01, 2009 | Nintendo Wii Play for Wii
Broken Wii?
so it fell from the shelf huh! try to replace your A/V cable with a new one.maybe it was pulled of when the wii fells causing the wire inside to get cut.hope this one helps!
Dec 21, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
