The tv will no longer come on. It won't respond to the remote nor to manual attempts. This has not happened suddenly. Over the past several days it has been gradually harder and harder to get the tv to connect. Once it connects, it seems to work fine.
  • graciemer Nov 14, 2010
    This is a Samsung LCD tv, model code LN40A530P1FXZA. No blinks when it is off, but it used to blink red and play the little "tune" while trying to start up. At first it would no longer respond to the remote. Then it would start up if I unplugged the tv and then waited a few minutes before plugging it back in. Then I could start it by touching the side panel of the tv, but it would take several minutes to connect. Now nothing - it won't start up at all. No smells evident.
  • 10,515 Answers
Kindly mention the make and model of the TV?
When it remains OFF, is there any specific sequence of blinks that you might have observed?
Any smell or any other symptom you might have observed?
Thanks!!
Posted on Nov 14, 2010
  • taran_2005
    taran_2005 Nov 14, 2010
    Thanks for your response!!
    It is highly suggestive of faulty power supply board. Samsung are known for these defects. If you have any electronics repair experience, you could open the TV and have a look at the Power supply board. You may find few caps - swelled / bulged / leaked , might have ammonia kind of odor.You need to buy new caps from radioshack or fry's and replace them. You need to do a bit of soldering and you should have multimeter to check the voltage across power supply board.
    Check and let me know,so that we could proceed.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
Tv does not respond to remote
Assuming it has been working in the past, and not a new or universal remote, my suggestion is to make sure and push the "TV" button on the remote. Since remotes can control several devices, it is easy to accidentally push one of the other buttons, then the TV will not respond.
Jan 03, 2018 | Televison & Video
What could be the problem if the remote is suddenly taking longer to respond
Battery is low or almost empty, change with the new one. And make sure there are nothing block TV receiver and remote control, plastic or paper or something else.
Feb 11, 2011 | Universal Remote Control MX-500 LCD Remote...
Please Help! We have LG Plasmas and both TV's when you go to turn it on it clicks on/off and won't come on at all. The red light turns green for a second and goes right back to red???
Hello.
You could have problem with power supply or sustain board.
If problem was developing slowly ( it was taking longer for TV to turn on, sometimes several attempts pushing power button on remote or set) than it is most definitely Power Supply problem that involved bad capacitors. If problem happened suddenly - it could be either or both boards involved.
I would recommend professional to diagnose it. If your TV is smaller than 40" - just forget about it and invest in new one. Repair will not be cost-effective.
Regards.
Russ.
Dec 01, 2010 | LG 50PG20 50 in. Plasma HDTV
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
SanyoDP26746 suddenly has no power .
There is no excuse to hold someone's gear hostage for a half-year. I hope for your sake that it was a 'factory authorized' service org.
If is was, contact Sanyo and raise Cain about it; this set seems to have way more problems than is common for the brand.
Sanyo Contact info
Jan 03, 2009 | Sanyo DP26746 26 in. LCD Television
TV will not respond to remote any longer.
have you replaced the battery ?. If so the remote may be faulty. there are buttons on the tv that will do all the remote can.
Nov 30, 2017 | GE RM24909 Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Remote No Longer Works
It appears the remote sensor in the Television itself has stopped working. If the TV is still under warranty I would try to contact the manufacturer to see what they can do for you. Can you still change channels manually? If so, this is most likely the case.
Dec 29, 2007 | Philips Magnavox 27MS343S 27" TV
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
