Furnace cycles properly for awhile then at some point when it fires up for the next heat call the inducer fan kicks in then the gas comes on for a few seconds then shuts off, I have tested all the flame and rollout switches and they all appear to be good. I next replaced the ignition module or ( brain ) and vacuum switch with O.E.M parts then the T`stat, problem still exists. What now ?????? the owner of the furnace replaced the flame sensor last year, i tested it as well and it appears o.k The unit is a trane MO# TUE080A936l3 SE# 4332J7Y1G. I would appreciate anything you can tell me to help them out, they are struggling and connot afford to hire a company. I am a freind and an RSES certified tech but am still at wits end thxs.
    President:
  • 1,891 Answers
Ck the exhaust and make sure its clear . i'M sure your are of birds and spiders . there web 's ect // the shut down of burner if poor exhaust is normal . and the inducer fan to clear ou gases is normal . but short cycling is often a hi limit problem . or poor air flow . i/M sure you have ck'ed the return air and filters . . and you might ck the blower to make sure the air movement over the heat exchange is proper . . this is just a ck & see list and hope it helps . it may even be a weak hi linit . .. mm
Posted on Nov 15, 2010
Trouble shoot Dayton gas furnace model GG9S100C16MP11A fan is left on constant but in cold weather 10 or colder fan will go off and furnace will go thru a restart mode and run fine for awhile then will do...
Do not run contentiously during heat mode. the fan runs at a slower speed with heat and heat fires first then the fan cycles on during heat cycle then when heat satisfies the thermostat the heat will cycle off and fan will run for a couple more minutes and then cycle off. So set stat on fan cycle to auto.
Feb 03, 2015 | Dayton Gas Furnace Heater
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
Plenum seems to be heating up but blower fan cuts out before it can blow heat through the house
Probably a bad fan/limit. The way it works is the heat comes on first then as the air gets warmer the bi-metal twist around on the fan limit and at around 110f the fan kicks in. If the fan don't kick on then the limit kills the heat so the furnace don't get too hot.
Newer furnaces use a computer board to drive the fan with a timing sequence.
Of course it could be something very simple such as a contaminated flame sensor. If your furnace if one of them fancy new fangled machines which use a draft inducer fan the control may not be sensing ignition and auto cycling on and off. if that is the case get a dry brillo pad and remove the sensor. Give it a good clean and re install it then retry:
Furnace Lockout
Jan 30, 2011 | Heating & Cooling
My furnace sometimes won't ignite. The blower will start to run, but the gas won't kick in. I have to unplug it and sometimes when I plug it back in - it will run a full cycle and heat up to the temp....
On a call for heat first your inducer motor starts if your furnace is equipped with one. Next a pressure switch closes and sends power to your ignitor it will glow or spark then the gas valve opens and you get fire now you have to prove flame to keep gas valve open this is accomplished by a flame sensor usually opposite end of ignitor. Let me know if this helps If you can watch it run and see it fail I would be more accurate with a diagnosis. Thanks
Dec 14, 2010 | Heating & Cooling
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
When turning on heat after a period of using air
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
The draft inducer comes on and the furnace lites as normanl Goes thru its cycle and kicks off. The problems is the draft may not kick on the next time and sticks and the motor gets hot, If I go remove the...
When a furnace is replaced with a newer style unit like yours with an inducer motor, they sometimes use the old vent pipe. These old style vent pipes are transite (light weight cement), the moisture created from your furnace exhaust is caught on the cool transite surface and runs back down into the blower blades or wheel bringing a white mineral deposit with it which causes your problem. The vent should nave been replaced with the heater using a metal vent material. You will need to replace your inducer motor assembly and vent pipe to prevent a recurrence.
Dec 04, 2009 | Omega Trane Furnace Draft Inducer Blower...
Gas Furnace is not heating anymore.
the fan you hear come on at a call for heat is most likely just the inducer motor. the click you hear is probably the relay for the hot surface ignitor which should glow red, then in turn ignite the main burners. your going to have to determine if the ignitor is coming on. if it isnt the ignitor is bad and will need to be replaced. if it comes on and than shuts off after a few seconds the ifc board is probably at fault
Apr 09, 2009 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
