Question about Poulan "Poulan" Push Mower
I just bought a Poulan Pro 21" 160cc Honda. 3-in-1 Push Mower PR160N21CHC and the blade caught and sliced the metal brace shaped like a V inside the housing. What caused the problem and what do I do to fix it? Thank you.
ccrozier_agr
  • 36 Answers
SOURCE: Poula Pro Mower
Hi,your machine is probably a hydro static drive & needs the oil changed in the transmission.
But the pump that pushes the oil around inside it is probably to far gone for repair.
I am not sure about this machine but we have had a simlar problem with a rideon this summer.
It has one pedal that you push forward for forward movement & rearwards to go backwards.
We were able to get a new drive pump for the transmission but it was expensive, most of these machines have nearly the same transmissions so getting the parts should be no problem.
Also we do know is that there are some machines with oil emersed discs inside (like wet type clutches) these also need regular oil changes & can burn out without oil. (Bronze plated disc)
You would need to find the name plate on the transmission & there should also be model & serial no on the casing.
Once you have these details you should be able to find transmission parts lists online.
Posted on Nov 29, 2008
  • 109 Answers
SOURCE: locked blade - poulan push mower
Check the oil level in the engine...if the blade is locked up, so is the engine, sorry
Posted on Apr 21, 2009
  • 84 Answers
SOURCE: carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Posted on Jun 24, 2009
mowerman1857
  • 389 Answers
SOURCE: HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
Posted on Sep 14, 2009
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
How to adjust throtle
The throttle on this mower is not adjustable.
May 26, 2014 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Lawn mower starts dies
Try running it with a loose fuel cap. If it runs fine the fuel tank vent is plugged. Some mowers have a little hole in the fuel cap that gets plogged up.Use a pin to clean it out.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Lawn mower idles low
Find a screw touching the linkage on the carb. Turn that screw to speed up the idle.
Just bought this mower honda hush arena 21 " push mower and it throws clippings all over the deck, why? Looks like its coming from the side outlet
See if the side outlet needs a plug underneath to keep the grass inside the deck to be mulched. A lot of mowers have these plugs but this one might have not been installed.
Jan 19, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Drive belt coming off
Check the pulley for any debris caught inside. If that doesn't help, you'll have to take it to a mower repair shop.
May 05, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Oct 16, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My troy built 7.75hp 21"
Turn the mower on its side pull plug There is a bolt on the bottom usually 9/16 inch unbolt the blade replace with new blade be sure to hold on to blade tpingo keep from moveing
Jan 24, 2018 | Garden
Where can if i find a replacement air filter for my 21" poulan mower? no one seems to carry them. It's a honda engine.
there should be a model number for the engine stamped on the mower somewhere. more than likely, you will need to buy the filter from a honda small engine shop as opposed to a poulan supplier. if you bring the filter in to your local honda equipment shop, they should be able to match it up quite easily. good luck!
Aug 29, 2010 | Poulan "Poulan" Push Mower
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
The pull gets stuck halfway up. Feels like it's tangled inside where the cord retracts. Is that possible?
It's possible it could be tangled, but more than likely you just need to oil the drive shaft. Dirt and debris and grass can get caught up in there and keep the shaft from spinning and the blade from turning.
If you turn your mower over and apply some oil or WD-40 on the shaft where it disappears into the body of the mower, then spin the blade (carefully!) and shoot some more oil in, the blade should begin to turn easier, and that should take care of your problem.
May 15, 2010 | Poulan Pro " Pro" Self Propelled Mower
Poulan "Poulan" Push Mower Logo
328 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
