Question about Video Game Consoles & Games
Connecting to xbox live through a cable modem and its failing the dns setting
    Problem Solver:
  • 13 Answers
Try changing ur security settings and make sure that ur network is enabled this is found under ur network settings
Posted on Jun 20, 2008
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Xbox Live On Westell C90-610030-06 Isn't Working
if this is the original xbox you have to use a crossover cable especially if your router is the same as your modem (both the same box) (try google for the crossover cable instructions.) if this is the 360 it should just work, also how is your router plugged into your modem or are they the same thing. If that is the case go get a linksys router and set it up so that your modem-router combo plugs into the linksys router which plugs into your xbox (note that this is a fix for the original to.)
Jan 10, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 live DNS test failed
if you are connecting directly to the modem, then you are going to need to get the dns info from your ISP. If you have a router just put the router address or let it find it automatically. Also check that the router has the right dns settings from the ISP.
Jun 09, 2008 | Microsoft Xbox 360 Console
Help settin up xbox live.
If you had a computer connected to this modem, it would also tell you that the DNS failed and you wouldnt be able to access the internet. This happened to me before. The DNS server is a problem on your internet service provider's side. Make sure that the modem is running properly. Also, if you still cant solve the problem, you can call them up, they may be able to fix the problem over the phone, if not, it could very much be a faulty modem. (They arent always perfect when they are manufactured and tend to die quickly.)
Apr 10, 2008 | Microsoft Xbox 360 Console
Xbox live connection
When your DNS fails, its not your fault, you are doing everything fight. The DNS is a result from your ISP. (Internet service provider). It could be because your modem is faulty or their service is just down at the moment. If you have a motorola modem, make sure that the 4 top lights are solid green. This problem just happened to me and i called brighthouse. They came to my house the next day, replaced the modem, and it was all free. They also credited my account for the 2 days it didnt work.
Mar 30, 2008 | Microsoft Xbox 360 Console
CAN"T SIGN IN TO XBOX LIVE
You might not have been banned. Not being able to connect to the DNS or having it fail can be caused by a few things:
The DNS address serves couldn't be reached
The info on the DNS server couldn't be snagged from your ISP or the DHCP server
The DNS values in the dashboard are wrong.
I don't want to come off like I am insulting your intelligence, but check your internet connection to make sure you have the ability to connect. I'm sure it is all in proper order. So the next thing you need to do is check to see if you IP is set and passes all the tests. If it isn't then you can click the more link on the test page to follow the directions on how to fix it.
You may also want to check out if you are using a XBOX live compatible ISP. Click on Learn More to see if you are using the right ISP or to adjust your settings. You can also check out the connectivity wizard to find out if there are some other issues revolving around this.
Still running into problems!?!?!? try running the modem directly into your XBOX. This has helped me in a few time of need.
Here are some helpful links on what you can do when your DNS fails:
http://xbox360help.blogspot.com/2007/03/dns-failed-on-xbox-360-live-test.html
And a link to a forum discussion regarding failed DNS
http://forum.teamxbox.com/archive/index.php/t-411837.html
Mar 04, 2008 | Microsoft Xbox 360 Console
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Joining XBox Live
Make an account offline that should work.
Feb 06, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
