Question about Zenith Televison & Video
Zenith 32" Model # 221-42180581
  • jtmcdiv Nov 17, 2010
    Thanks. As suggested I am calling the repair shop this morning.
    The reply from Silverdragon was prompt and easy to understand.
    All the best, Jack
    Thanks, your response is very helpful.
  • Zenith Master
  • 12,061 Answers
That "rapid thumping sound coming from inside" (sic) Well, this is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions. These problems can just spontaneously occur, usually it is to do with simply being connected to the power lines.. the sets are always subject to spikes surges, most often with no damage but sometimes there is, as i suspect in your case.
It is my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Zenith in your case. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Nov 15, 2010
I have zenith tv need code for remote to run GPX Model #d220B dvd player the TV model # c32a26
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Apr 30, 2017 | Zenith Televison & Video
My Zenith c32a26 tv is losing color, there is a discoloration circle around the screen, what do i do?
Degaussing posistor to your TV has damaged. Contact any service technician.
The component will look lie this, can be located at the main power supply regulator section circuit. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Zenith C32A26 32" TV
First it turned green for a while and then turned it off, and I can turn it in again.
Sorry, you have described the classic shorted CRT (picture tube) for this unit. Another problem could be the CRT socket. Less expensive to repair. Both would require a trained TV technician to repair.
Feb 18, 2011 | Zenith C32A26 32" TV
I am using windows service pack 3. I have also installed audio drivers of zenith. but no sound is coming. I have just format the computers two days ago. I have used Zenith motherboard driver to install...
Assuming that this is Win XP or Vista, reinstall the Zenith Audio Drivers again. If you have any issues then check that the aduio is Ok by looking at Device Manager from Control Panel. This will show any issues with the hardware and the device drivers.
Assuming that you have an MSI or Gigabyte motherboard check the model number and then get the latest drivers from
www.msi.com
or
www.gigabyte.com.tw
Sep 10, 2009 | Computers & Internet
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
C32A26 crt TV; No audio or video
Mmm this is tricky - there is no normal transformer power supply in a tv. They usually just rectify the supply and regulate it for the circuits, and use voltage doublers and a transformer to get the EHT. Be carful the voltages can be 20,000volts! Check all the capacitors. The EHT flyback transformer can arc and present a clicking sound. Make sure everything is clean.
May 12, 2009 | Zenith C32A26 32" TV
Zenith C32A26; Sudden Video and Audio Failure
Try plugging it into the outlet directly. Your surge protector may have died.
May 09, 2009 | Zenith C32A26 32" TV
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Televison & Video Logo
95 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
