Question about Dell 942 All-In-One InkJet Printer
Carriage slams back and forth - Dell 942 All-In-One InkJet Printer
    Problem Solver:
  • 5 Answers
I cleaned the encoder strip with alcohol and a soft T-shirt. IT fixed it for me.
Posted on Dec 07, 2010
Hp 7520 carriage slams back & forth
Sounds like a defective printer that you may need to replace. If you ever need the ink for it, please let me know. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
After replaceing an ink cartriage every time I turn the printer the ink tray slams to one side then all the way back I gert an error message to start it again and slam bam. I hope you can help.
The encoder strip may have come out of the sensor slot. Turn off power, slide cartridge carrier to center, place finger on each side of encoder strip which runs behind the carriage and push the encoder strip down and back up, slightly back and forward if necessary to get it into the sensor slot which is located behind carrier. If it is in slot, sliding the cartridge carrier back and forth to see if therre is movement. If so repeat.
Dec 26, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Clear carrier jam is error message
Not that difficult check if behind the carriage(part holding cartridges) has broken off.Its a small plastic latch about 3 inches in length.
If not then try moving the carriage manually with your hand and see if it moves if it doesn't press and hold the power button and while holding the buttons unplug and re-plug the power cable to the printer .Clean the carriage rod with alcohol on a cotton swab/lint free cloth and then see if the problem surfaces if it does then its time to get a new printer
May 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
The part that prints goes to right and tries to go further to the right and doesn't print.
Look for a plastic strip where the ink station moves back and forth. It has tiny vertical lines on it which count as the carriage moves. If the strip gets dirty, the carriage may lose count and slam against the far stop. Power off the printer and gently clean the strip with a damp rag. Rub both sides with the rag dampened with water. Then make sure it's dry and see if that doesn't help.
Apr 30, 2009 | HP DeskJet 932c InkJet Printer
When ever I start to print it sounds like automatic weapon fire. It seems to be coming from the ink cartridges...replaced both of those and still same issue. Help would be greatly appreciated as in this...
It may be that the carriage sensor is either broken or moved out of place. When you power on the printer, it will move the carriage back and forth to find the end sensor. If it doesn't find it, it will slam against the end and cause the sound you're hearing. Look on the side of the cartridge for a tab or ear and make sure that there isn't any obstruction in the carriage path that would impede motion. Also check to see if the sensor isn't out of place.
Mar 17, 2009 | HP Photosmart C4280 All-in-One InkJet...
Printer Carriage Violently Slams Back and Forth
The encoder strip is out of it's way, or is removed...
Dec 03, 2007 | HP Deskjet 5440 InkJet Photo Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
