Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
My Frigidaire GS26HSZCBO icemaker inlet tube keeps freezing when the ice maker arm is up in the off position. If you keep the arm down its fine but you have to keep throwing out ice because I can't use it as fast as it makes it. Any suggestions?
  • 833 Answers
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
  • 449 Answers
SOURCE: ice maker and water dispenser does not work
Check the inlet for clog, also check to see if you're fitting the filter right. the part where you have to press to release the filter should come back to it's normal position when you insert the new filter.
Posted on Dec 17, 2008
tborn6
  • 700 Answers
SOURCE: Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: FRIGIDAIRE SIDE BY SIDE FRS26LF8CSN
alkimike;
I had a problem with my icemaker not drawing water or making ice, I did a full defrosting of my freezer taking everything out leaving the door open for about 1.5 hours It appeared that the inlet water supply had an ice blockace up in the water outlet, defrosting it cured the problem, it has been workinf fine for the last day tub is full of ice!!
Posted on Jan 29, 2009
  • 4 Answers
SOURCE: Icemaker fill tube keeps freezing up.
The reason your fill tube to the icemaker is freezing up time and time again is simply the valve, or valves (water valves) that dispense water to the door and icemaker. It most likely always is the icemaker side because it is always harvesting ice and it gets used the most. The only way to stop this is to replace the water valves almost always located in the rear of the Refrigerator with the supply line coming off the wall the valves with one or two electric plugs that energize the solinoid type valve when unit calls for water. Tired of getting out the hair dryer and melting the ice that plugs up the fill tube? This is the only solution. Some of the time is because lime, or other deposits in the water will not allow the plunger to rest in the complete closed position. When the valve is energized for the amount of time needed it lifts the plunger allowing water to flow through. Then when it goes back down
to the closed position it has a small gap that causes water to seep through. There you have it! It's fixed! Unplug unit before replacing valves.If you have a double valve system make sure your lines go back to the original spot. Some of them have a 1/4" line with plastic compression fitting for the icemaker and a 3/8" for the water at the door. Some have both 1/4" compression fittings coming out like "Amana" so once again, make sure to get all lines back to the same possition. Free info. from-
Randy Browne
Appliance Installtion & Repair
San Antonio, Tx. 78209
210-822-1818/210-493-2700, cell# 210-264-1471
Posted on Feb 26, 2009
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Water keeps building up and freezing in the tube to the icemaker and on the wall where the tube comes in...
Replace the water inlet valve. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Dec 01, 2010 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Hi, Could be many things. First make sure temp in freezer is close to 5 above zero. Then make sure the ice level arm is going all the way down position. Make sure water is geting to icemaker. Sometimes the inlet tube to the icemaker freezes up where the inlet tube goes through the rear freezer wall. Worst case is that the icemaker its self is bad. Let me know if I can help you further.
Vic
May 11, 2009 | Refrigerators
ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
Jun 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
