Question about Toshiba 40E200U TV
40e200u. brand new. just turned it on and the power light is on but the screen is black. pressing the menu button on the remote or the tv does not do anything. cable is hooked up and it has sound but no picture.
  • Toshiba Master
  • 8,457 Answers
Call Toshiba customer serviced for a warrenty repair or take it back were u bought it.Tries get a new replacement tv.The tv have dead of those 2 long LCD inverter boards,that why ur tv is getting only sound but no picture.
Posted on Nov 14, 2010
  • Harman Grewal Jan 06, 2011
    I have same problem what could be wrong in inverter board caps r fine and fuse is good
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
    While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
    Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    Remote control not working with tv
    The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
    The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
    Dec 02, 2010 | Philips Televison & Video
    Power light blinks 13 times
    need replaced A-BOARD
    Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
    After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
    1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
    2. Press the number [2] key on the remote to highlight [SRV-TOOL].
    3. Press the [OK] button on the remote control to select [SRV-TOOL].
    4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
    5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
    6. Press and hold the [RETURN] button on the remote control until the TV turns off.
    7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
    8. Remove AC power.
    Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
    Tv2 light does not come on
    hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
    Jul 06, 2009 | DISH Network 322 DTV Receiver
    Brand new LG plasma stuck on test screens
    Resetting the TV
    If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
    NOTE:
    Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
    1. Unplug the TV power cord from the power outlet.
    2. Unplug any connected devices (DVD, Set-top boxes, etc...)
    3. Press and hold the TV power button for five seconds.
    4. Plug the TV power cord back into the power outlet and turn on the TV.
    5. Open the on-screen menu to confirm that the TV is responding again.
    6. Turn off the TV and reconnect the devices.
    7. Turn on the TV.
    Hope it may help you;
    Regards;
    VOTIT
    Jan 29, 2009 | Televison & Video
    Hi,my brand new UHF remote wont operate the #2 tv??
    Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
    Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
    LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
    Good Day, texxastam;
    Do this:
    1. UNPLUG TV
    2. HOLD IN VOLUME DOWN &INPUT buttons on TV
    3. Plug in the TV. (the TV will turn itself on).
    4. A blue "K" should now be showing on the TV screen, release the buttons.
    5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
    6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
    7. Using the remote, press VOLUME UP once (OFF changes to ON).
    8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
    9. Unplug the AC cord for 10 seconds then plug back in.
    Good Luck, big IRISH.
    PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
    Aug 07, 2008 | Sharp Televison & Video
    Toshiba 40E200U TV Logo
    378 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
