Question about Quasar VV1309 13 in. Combo
I can't hook up my dvd player to my quasar model v v 1309 because we don't have a remote and can't change the input. The screen is blue and the channels change.
  • Quasar Master
  • 5,189 Answers
You should be able to change the input mode by changing the channel up or down past the regular channels (so channel down 3, 2, 1 > Line > 125 (if cable source) or 69 (TV source).
A replacement remote can be gotten from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=VV-1309&uuid=12897739886740 . With the remote, press Action and then enter the menu then choose Input Select and then choose Tuner or Line.
I hope this helps.
Posted on Nov 14, 2010
I have two problems. One I cannot access changing the time etc. That screen will not show when I go through SETUP. How do I change? Secondly, I have a DVD player hooked up to my Olivia TV. How do I get...
You can access the set up mode menu if you have the TV mode.
The DVD should be hook up to the TV using A/V inputs using yellow, red and white cables and select A/V 1 or any other input where the cables are connected to.
Sep 09, 2008 | Televison & Video
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
Trying to get my TV can't find manuel or remote
Press the "Input" or "Source" button on the television while you have the DVD player on. Press it repeadly until you see the DVD picture on the screen.
Basically, just try changing the input on the TV to the input that the DVD player is hooked to.
If this doesn't work, you may have to get the original remote, or get a universal remote to control some of the television's features.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Televison & Video
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia Televison & Video
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
HELP PLEASE
you should be able to use the control panel on the set, sometimes it's a little tricky, but if you keep trying you will get the right settings
Feb 12, 2007 | Quasar VV1309 13 in. Combo
Quasar VV1309 13 in. Combo Logo
235 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
