Question about Norcent Technologies DP313 DVD Player
When I turned the dvd player on the three lights were flashing and it wouldnt play dvd. the menu screen wouldnt even come on.
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
I need a region free code for my Insignia NS-BRDVD player (a bluray/DVD player purchased in Canada).
This worked for my NS-BRDVD2-CA, basically the same model as yours.
1. Turn on the player.
2. Press the home/setup button and release. Enter 9-1-1-3 on the number pad.
3. "Configure player" appears in the wheel menu to the left of the screen. Using the up or down arrow button on your remote, navigate to it and press enter.
4. Three menus appear on a blue screen in the centre of the set: DVD Region, BD Region, and BD Profile. Select the one you want and press enter.
5. A grey screen appears in the centre showing the various regions. Navigate to the one you want and press enter.
6. Exit the grey menu by pressing the left arrow key, then press it again to exit the blue menu. The screen will appear as it did in step 3 before you pressed enter.
7. Open the drawer and put in your foreign disc. Wait a little bit. When it's ready, the disc's main menu appears. Play it like you would any disc.
8. Voilà! Consider yourself fortunate: You're now able to play foreign DVDs and Blu-rays on your cheap North American player.
P.S. Remember that you have to do this every time you want to play a foreign DVD, because when it's shut off the player automatically defaults to Region 1 for DVDs and Region A for Blu-rays (i.e. North America for DVD and the Americas for Blu-ray). The "configure player" menu disappears sometimes, too; to see it again, simply re-perform the "home/setup, 9-1-1-3" hack.
Aug 15, 2010 | Insignia NS-BRDVD Blu-Ray Player
My DVD says "root" on the screen. What do I do to get it to play?
"Root" is part of the Menu screen, press Menu on the remote to clear it.
Jun 05, 2010 | Philips Magnavox DVD/VCR Dual Player
DVD is playing but you don't see it on the tv . Do I have to put TV on a certain channel while playing DVD?
pls check dvd AV cabel .
if ok
then
playing dvd first and see dvd back side pin .
VIDEO OUT
after see on your dvd remot cantrol and check interface key if yes then use key to set display on screen S-VIDEO and see the picture is normal .
if not then.....
pls see the dvd back side
GY /BU /RV three pin
pls video out pin is plugge out and concting with step by step in all three pin
if sum picture on screen pls. canect and hold .
after that use dvd remot cantrol and selact SETUP key to on and see and open video interface menu pls set video system is select S_video.
after that reconact video pin is VIDEO_OUT and see picture is normal .
Oct 08, 2009 | Panasonic DMR-E75V DVD Player/VCR
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Sep 03, 2008 | Jensen's VM9312 Car DVD Player
Not playing
im not sure if this is going to help, but it helped when mine wouldnt start. take off the top frame of the dvd player so you can see part of the disk tray. put the dvd in and if you notice that its not spinning, then try spinning it to the left with your finger.
Jul 14, 2008 | Cyberhome CH-DVD 300 DVD Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Norcent Technologies DP313 DVD Player Logo
14 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
