Question about Furuno GP1650DF GPS Receiver
Depth sounder problem
My furuno gp1650-df is giving a false depth reading. Can these be recalibrated or is there other prolems that could cause this?
    New Friend:
  • 132 Answers
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Posted on Jan 19, 2010
How do I replace the internal battery on a furuno 1650
Hi
I realize this question is a little date, but in case anyone else has the same query I'll provide a link to the owner's manual. Replacing the battery/fuse information is on Section 12-2. The battery is a CR2450-F2 ST2.
Hope this helps.
-Steve
http://www.furunousa.com/ProductDocuments/GP1650%20GP1650D%20Operator%27s%20Manual%20N3.pdf
Sep 22, 2014 | Boating
Where can i get a manual for a furuno gp1650 chartplotter
Here is a link for the manual.
http://www.furunousa.com/ProductDocuments/GP1650%20GP1650D%20Operator's%20Manual%20N3.pdf
If the link doesn't work go to furunousa.com and enter unit model number in search bar. Select the unit then select the manuals and documents tab. Operation manual is there and can be viewed and/or downloaded in pdf format.
Nov 04, 2013 | Furuno Boating
I have a used gp1650 f, gps fish finder. It has a white, black, & an open wire(looks like a ground strap) and need to know how to wire it correctly.
Hi!
According to the Furuno installation manual:
http://www.furunousa.com/ProductDocuments/GP1650F-GP1650DF%20Installation%20Manual%20%20n.pdf
The white wire connects to +12v, the black wire goes to battery negative and the shielded braid connects to a common ground on your vessel to minimize RF interference.
In case you require an owners manual, you can view/download it here:
http://www.furunousa.com/ProductDocuments/GP1650F-DF%20Operator's%20Manual%20Version%20M.pdf
Hope this helps and Happy Boating!
Jun 21, 2011 | GPS
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I can never read the fish on the screen of my sounder whether is in auto or manual mode (yes we are catching fish)
perhaps someone has messed with your sounder settings. You may want to factory reset the sounder from within one of the menus in your navnet. Also you may have a transducer going bad. Did you hit anything with it or run aground once? Maybe someone painted over the face of the transducer with bottom paint. There's alot of things that can cause this to happen. It would be best to have the sounder checked out before you do anything to the ducer. Remove your navnet and sounder and take it to a dealer to test on the bench. If you're in the maryland area, Mid-shore Electronics and handle this for you. Even if you're not, you can send the units to them.
Dec 31, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
My furuno depth finder gives me crazy depth readings after i go over 10knots..whats the problem?
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
Nov 03, 2009 | Furuno 1850WF Gps Fish Finder Combo...
When I turn on the unit it will not read the depth only a blue screen and it will not let me switch out of auto mode or run the sounder test?
I know this is an old question but just ran across it. The 1833C/NT is a radar and chart plotter. It requires the external and optional black box sounder to have depth recorder functionality.
Oct 03, 2009 | Furuno 1833C/NT GPS Receiver
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Furuno Colour Video Sounder FCV-68 tech diag need.
most are available from furuno, but not FCV 68 are you sure that is the model #?
Apr 11, 2009 | Furuno 1623 Radar 16nm Range
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
Furuno GP1650DF GPS Receiver Logo
445 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
