Question about Bulldog Remote Stater w/Keyless Entry and 2 remotes
I need to get a replacement remote it is a TX2BD, and I want to get 2 of them.How do I go about doing this?
  • 391 Answers
I have 2 craftsman garage remotes and they do not work. Replaced batteries and still not working. The numbers for the remotes are 139.18790B and 139.18791B. Needing some advice please
First question Did they work with this opener before? If Not then they probably need to have the code set in them. There should be a set of switches inside the remote that are used to match it to your opener. If they worked before then it is possible that they have a bad circuit on the board or just a bad battery connection.
Sep 12, 2014 | Building Materials
I have 2 remotes for my 2007 Honda CRV, 2 that unlocks the doors and 2 with a button you push to start the vehicle. One of the starter units won't work. I took it apart to see what kind of battery it...
Typically a car remote does not have to be reprogrammed to replace the battery. Check the car's owners manual to verify the battery is a CR1229. I don't know of any 1229 number but I do know a CR1220. Verify the number and you can buy them at just about any store...from Walmart on.
Semper Fi,
Z
Aug 08, 2017 | Prestige Remote Start
Is Visio Model VA220E remote a version 1 or version 2?
Version 1 should be the original remote.Version 2 is a newer style of remote.
Part number of your remote that is needed is 098TRABD1NEVZU
Feb 18, 2012 | Vizio VA220E LCD TV
Replacement remote not working after 2 years replaced batteries still not working tv works fine manually do i need a code to reprogram the remote?
it is possible, also check batteries and infrared on television and remote, they may need to be wiped clean. try checking manualsonline.com for appropriate manual for remote codes...without model of remote, i could not check for codes for you.. sorry.
Oct 17, 2010 | Protron PLTV-32 Television
My remote no longer works
Hi. If the software is saying that the update may not be intended for your remote, then all you need to do is a connectivity check. To do this:
1. Click on the "Remote Settings" tab.
2. Click "Manage Remotes."
3. Connect the remote to your computer.
4. Click "Replace Remote"
5. Update the remote.
Apr 09, 2010 | Logitech Harmony 890 LCD Remote Control
My remote shows SAFE MODE, what do i need to do to get it to work again?
Press on #2 remove batteries, keep pressing on #2 and replace batteries. Worked great.
Thanks to all
Merry Christmas
Dec 21, 2009 | Logitech Harmony 520 LCD Remote Control
I have a 2004 tacoma. Remote starter doesn't work. Dash lights on right side of the dash are dim. Remote starter was pro installed 4 years ago. Any ideas? Thanks
look under dash for the unit, remove the 2 fuses in red jackets wait 2 minute then replace fuses
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Dec 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
Safe mode
To get your 550 out of safe mode, follow these steps.
1. Remove the batteries.
2. Hold the '2' button down.
3. While still holding the '2' button down, replace the batteries.
4. The remote will boot into the normal functionality.
Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'.
Sep 29, 2007 | Logitech Harmony 550 Remote Control
Bulldog Remote Stater w/Keyless Entry and 2 remotes Logo
171 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
