Question about Dishwashers
I own the Siemans SL34A006UC dishwasher which had the recall repair completed. Now it doesn't work right. The unit goes through any of the cleaning choices but when it comes time to drain, the unit stops for a few seconds, swishes water for a couple seconds, stops again, then swishes for a couple seconds, stops and then goes back in to regular cleaning mode until the timer reaches zero. At each drain cycle, it does the same thing earlier mentioned 3 times in a row, then back to washing. The unit knows not to add additional water in that none was drained out. I have cleaned the main drain screen, taken our the main filter, removed the single screw for access to the propeller and it turns freely. I have checked the drain line for kinks, clogs, etc., it has been hooked up to the sink correctly for several years but cannot figure out why the unit will not drain. I have run recommended cleaners through the unit as well., but to no avail.
  • 12,061 Answers
You say "dishwasher which had the recall repair completed." (sic) "Now it doesn't work right" (sic)
Being a professional I must advise,and that, if this is the case, then you must get the people who performed the "recall repair" to attend to the matter for free. It is their duty to put right any problems that may have been caused by the work they have performed. It is NOT co-incidence that there has been a "repair" and now you have a further problem.
What you are indicating is most likely the pressure sensor? or some other sensor, or even a "Brain" fault, but until one actually examines the machine it's hard to tell, exactly sometimes, as many symptoms are the same but with differing causes.
as related this must be attended to by the recall repairer, as most likely, either whatever they have done, has caused a problem, or what they have done, has "Stressed" "other" componentry, that should have been upgraded to cope with the recall repairs whatever they were.
Always be firm but polite and indicate exactly what you want done and why...you may get initial resistance, however persevere as you are doing the right thing for the right reasons,and you will prevail.
Posted on Nov 15, 2010
No power
Hello
Plug the Siemens dishwasher into a working electrical outlet if nothing on the dishwasher is operating. Check the household circuit breaker or fuse and reset or replace as needed.
Push the door closed fully if the dishwasher has power but isn't starting. The unit will not operate if the door is open.
Sep 11, 2011 | Siemens 24 in. SL34A006UC Built-in...
My SL33A002UC dishwasher is taking 4 hrs to complete a wash cycle,
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
Feb 07, 2011 | Siemens 24 in. SL34A006UC Built-in...
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Frigidaire dishwasher model pdl4375rfc2 serial# th80537081 door weaks aat lower right corner user less than 6 months is there a recall on this model
if unit is less than a year old . call for service 1-888-203-1389. this unit has a one yr. warranty from the manufacture. recalls are usually not given on appliances unless it is a safety issue. however i have repaired alot of these under warranty for your same complaint. their is a splash kit u can get that goes on each corner of the bottom of the inside of dishwasher that will stop it from leaking, roughly 10-20.00 dollars depending on who u purchase it from .hope this helps out.
Oct 06, 2009 | Frigidaire PLD4375RFC Dishwasher
Siemans dishwasher not draining
the water in the bottem of the machine under the mesh filter is normal. it acts as a lubricant for both motor impeller and drain propeller. if its greasy then try using only 1 tablespoon of powder soap from now on. now if the water level is ever above the mesh filter after a complete cycle, then you have a drain problem
May 25, 2009 | Dishwashers
No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Mar 03, 2009 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
Top Dishwashers Experts
