Question about HP PSC 950 All-In-One InkJet Printer
Check color cartridge
I changed my color cartridge and I still the error message to check the color cartridge. Can you help me
  • 94 Answers
Sounds like it thinks it isn't installed right. check all the contracts, ink & in the printer.
Posted on Jul 10, 2008
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
Oct 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
"Check color cartridge" error message
Try resetting the printer to factory defauts. Hold down the # and 6 buttons. Pull out the power cable while holding these buttons down. Keep your fingers on these buttons and put back the power cable. It should now show (full/partial reset). Follow the prompts and setup all your original features. If this fails then you might have a hardware problem.(Carriage assembly or Cartridge Holder)
GOOD LUCK
Jan 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Ink cartridge problem
    Complete the following instructions:
    1. Power off your All-in-One.
    2. Use both hands to lift up the scanner unit until the scanner support holds it open.
    3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
    4. Remove the color print cartridge.
    5. Lower the scanner unit until it is completely closed.
    6. If the error message reappears, replace the black print cartridge with a new print cartridge.
      If it does not repeat steps 1-3 and then go to step 7.
    7. Reinstall the color cartridge and remove the black print cartridge.
    8. Lower the scanner unit until it is completely closed.
    9. If the error message occurs again, replace the color cartridge.
    10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
    11. Lower the scanner unit until it is completely closed.
    12. If you receive the error message again, replace both cartridges.
    Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
    Changing cartridges
    I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
    I just used it yesterday, what is wrong???
    Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
    HP PSC 950 All-In-One InkJet Printer Logo
    103 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
