How do i repair my acer laptop?The problem is that when I on it,it shows windows error ./32 or sumthing like that.
    Brigadier General:
  • 8,909 Answers
You have a hard drive error. Try booting from your system disk, if that works run CHKDSK/F and that should fix the error.
Hope that helps.
Posted on Nov 14, 2010
My acer aspire 5515 laptop system error window show when I try to boot. Hiw do I fix it?
so what i guess its giving mbr not found and its not booting , the solution is you need to have the windows operating system disk and then when your acer laptop starts to boot click on f8 then click on repair windows then after that you will see 3 option click on the third it will say repair cmd then type as what is given below
Click on the "Repair Your Computer" option to gain access to the System Recovery window. Now choose "Command Prompt" to run the Bootsect.exe utility. Bootsect is located inside the boot folder so change your directory to boot. Now run "bootsect /nt60 C:\" (without quotes) if you had Windows 7 initially installed in the C partition. Alternatively, you can run "bootsect /nt60 SYS" or "bootsect /nt60 ALL" (without quotes) to repair the system partition or all partitions. Eject the DVD and restart your computer. Your computer should now boot Windows 7 again.
Read more: How to Repair the MBR on Windows 7 ' eHow.com http://www.ehow.com/how_4836283_repair-mbr-windows.html#ixzz2CY96TyX0
Nov 18, 2012 | Acer Computers & Internet
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
System32 error or corrut
System 32 error can only be rectified by booting the system with a Windows cd and then running a repair.
Thanks
Dec 30, 2009 | Acer Aspire 5100 Notebook
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
My acer aspire 4710 is not getting started,and
This laptop needs to be serviced if its showing a hardware error. You did not go into detail on the error message so its hard to tell what diagnoses to give. I would call Acer directly and have the laptop repaired if its still under warrenty,
Any hardware error in a laptop can be complex so look into repair locally would be my best suggestion. Please do rate my solution as we strive for ratings- Thanks
Aug 19, 2009 | Computers & Internet
Acer Laptop Windows does not start up."system dll 32 file missing
take the drive to another computer to recover lost info then format it and reload a new install from the disk,then copy what you want back on to your computer,You will have a working system in about an hour
Hope this helps
Cheers MISTERDJ
Aug 16, 2009 | Acer Computers & Internet
Acer aspire 3680 white screen
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
Mar 30, 2009 | Acer Aspire 3680 Laptop
My acer aspire 5100 keeps coming up with an error code when switched on, and does not allow me to even restore to another date when computer was ok. the code is ERROR LOADING C: WINDOWS\SYSTEM 32...
do you have the restore cd? Using a restore cd would remove your files but it would fix the problem.
if you can get your hands on a windows installation disk, for the version you are using. You could perform a repair installation, it would also fix the problem and you would get to keep the files.
a pc tech might be able to fix the problem without reinstalling windows but that would require you to take the laptop to someone.
I know I could but I'm not in the UK.
Jan 14, 2009 | Acer Aspire 5100 Notebook
Acer orbicam has stopped working
Download the driver for Acer orbicam, here is the url to the site,http://support.acer-euro.com/drivers/notebook/as_3680.html.if it doesnt work go to the bottom of the same site and click the link saying FTP site in green,works like magic
Dec 05, 2008 | Acer Aspire 3680 Laptop
Windows error recovery
you need to run a repair on your OS. For you to be able to do this, you should have ith your the recovery CD that comes with your unit.
May 18, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
