Question about RCA P46924 46" Rear Projection Television
RCAP46924 turns on by itself then constantly changes channels . Remote will not work.
    Brigadier General:
  • 8,909 Answers
Check for a sticky channel up or down button on the TV.
That will cause that problem.
Hope this helps.
Posted on Nov 14, 2010
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Jul 04, 2008 | Dell W2300 23 in. HD-Ready LCD Television
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Feb 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Channel constantly changes on TV
YOU HAVE BAD BUTTONS ON THE FRONT PANEL THEY ARE STICKING OR ARE SHORTED.
Sep 14, 2009 | RCA P56950 56" Rear Projection Television
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
Tv changes channels when turned on.
Be sure your remote hasn't got a button stuck down which is changing channels. If not, take the batteries out of the remote. If this stops the channel changing there is probably some conductve material stuck across the circuit board
inside the remote. If this is the case you have to check inside the remote by openning it up.
Jan 28, 2009 | JVC AV-27530 27" TV
Constant channel box on screen
There should be a button on the remote called display and this should turn off the channel display. If it dosent then have the remote checked and make sure its working in that function. A universalo remote wont work as well in most cases. Good Luck
Jul 02, 2006 | Sony FD Trinitron KD-36XS955 36" TV
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Apr 01, 2006 | Bush WS6671 28" TV
RCA P46924 46" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
