Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE Refrigerator stopped cooling
My refrigerator has stopped cooling....it is showing 50 degrees inside. The freezer has stopped cooling as well but I hear a fan going but it is not blowing from the top as normal. The icemaker and water are still working.
  • 1 more comment
  • seab2 Jul 16, 2008
    Opened my refridgerator door and it was 109 degrees! with the butter running down the door.
  • girlie4560 Aug 03, 2008
    i unplugged it.
  • hamliton_jay Sep 01, 2008
    I have the same problem were the ari is not blowing from the top.
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Posted on Oct 30, 2008
Freezer and refrigerator stop getting cold
Most likely it has a coolant leak or the compressor is bad. I would call GE as there may be a recall to repair this no matter if you are the original purchaser or not. Although with the amount of computerization in home appliances, it could be a main circuit board going bad.
Feb 12, 2014 | GE PSC23SGPSS Side by Side Refrigerator
GE model tbx14sisdrwh fridge. freezer works fine but the fridge will only cool to 50 degrees can anyone tell me the problem thank you.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
GE refrigerator is cooling to 48 degrees F, but the setting is at 37 degrees F. The temperature on my furnace is set to 70 degrees F. Is this affecting the refrigerator?
The freezer may be overcrowded with food in this case cold air from freezer is not migrating to refrigerator compartment. Inside the refrigerator, at the bottom and on top, there are opening sliding door that allows cold air from freezer to circulate in the refrigerator. Make sure that they are not obstructed. Or simply, your refrigerator condenser is dirty and may need cleaning. If neither of this is the solution, get a repairman to check or fix it for you.
Dec 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not completly filling. Freezer not defrosting, coil icing. New this AM fridge section not cool running 50 degrees. Fan in freezer running. Defrost unit replaced at some time in past.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | GE Refrigerators
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Fridge part is 50 and Freezer part is 40
If your refrigerator is the model TFX27PRBWW then in photo below you see the defrost timer inside the fresh food compartment hidden by a cover. Turn the timer slowly clockwise until refrigerator stops. This should be defrost cycle. 30 minutes later the refrigerator should restart again, if not we need to replace the defrost timer. Go to link below and enter your model number that will take you to many of the same type just pick the one nearest yours. On left of screen choose the 4th photo down that is the part I'm focused on now. Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
357 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
