Question about Lexmark X4650 InkJet Printer
Lexmark 4650 printer will not print. It says it is offline. Haved tried turning everything off and checking connections but will not print.
  • 30 Answers
SOURCE: Lexmark z23 cartridge banging
Unfortunately, this is a known problem with Lexmark printers. First, try turning the printer upside down and shaking it - it's been known to work. If it didn't help, try cleaning the parts with alcohol solution. Wipe everything inside including the top strip, the metal bar and then pull the ink cartriges out and wipe the copper and the actual cartrige too. And to finish it, hit the side of the printer a couple of times.
Posted on Apr 05, 2006
Ajkill
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
SOURCE: Print server thinks printer is offline
Disconnect from the net and turn off your firewall while trying to install.
Posted on Jul 31, 2008
SOURCE: how do you reset printer chip in lexmark ink
open the lexmar productivity center
activate the wizard and click on "change printer cartridge"
take the printer catridge out and wait 15 seconds
reinsert the refilled cartridge
confirm change
when asked if the inserted catridge is new, answer "yes"
sorry, I translated this from german..
Posted on Nov 12, 2009
Printtech
  • 1087 Answers
SOURCE: Is there any way to get Lexmark z600 working on
There is no Lexmark Z600 driver specific for Windows 7, however, the Vista driver works. Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. Download the driver using this link: http://bit.ly/cd4MzI(for 32-bit) or this link: http://bit.ly/c4xCtN(for 64-bit). Execute the file to install the driver. If you need further assistance, you can also contact Lexmark technical support. Thank you for choosing Lexmark.
Posted on Sep 16, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Need illustration of everything that should be plugged in on the Lexmark X4650. Have been fighting this thing to get it to print, for the last week. Thanks.
There are 2 connections that are needed to be done on the printer. One is the AC adapter and the other one is the USB cable that connects to the computer.
mariolands_7.jpg Also you can read about setting the printer up in the User Manual: http://www.lexmark.com/publications/pdfs/2007/4650/v12364191_en.pdf
And you can read here about Wireless Setup.
Dec 02, 2010 | Lexmark X4650 InkJet Printer
How can you print with a lexmar 4650 on a sylvania netbook
Access the web-site for the manufacturer of the printer: http://support.lexmarK.com
Enter '4650' and do the search.
Select your printer.
Select your Operating System.
Select the device-driver.
Download the device-driver.
Install the device-driver.
When prompted by the installer, connect the printer to the NetBook.
Nov 04, 2010 | Sylvania G-Netbook
I installed new cartridges in my X2550 Lexmark I want to print a test page. It scanned the test page but will not print it. What do I do?
it depends on the error message why the test page won't print. If it just won't print at all, try to reseat the paper into the printer and turn off/on the printer then try to print the test page.
If it doesnt, then turn off the printer, remove cables. And then press and hold the power button on the printer for 5 seconds . Reinsert cables and turn on the printer and print the test page anew....
Jun 04, 2010 | Lexmark X2550 All-In-One Printer
Cant get my lexmark 4270 series going on my computer help
Go to Control Panel -> Printers. Is the printer listed here? Is the printer Online (It will say Online or Offline next to the printer tile)? If it says Offline, the computer cannot currently see the printer so check to make sure it is plugged in and turned on and that the cable is connected from the computer to the printer. If it is Online, right-click on the printer tile and select Properties. On the General tab, click on the Print Test Page button. After a few moments, the printer should spit out a test page. If this prints out, your printer is working properly. If not, let me know what error messages (if any) it displays or the overall printer behavior (blinking lights, beeps or other noises, etc).
Apr 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark printer error messagenicating with the computer
The books for most printers are so useless to us they may as well be burnt. I get fed up with useless info. Very rarely of help. My first suggestion if you are running the correct driver for your OP, and your printer was previously fine, is to check if the printer queue is blocked up with too much memory from print jobs.
Go to the quick launch icon in task bar at bottom of your screen, right click on the printer icon, and bring up printer jobs window, scroll down to cancel print jobs. Now, once done, turn off your printer. Let it sit off to reset it. Turn it back on and try to reprint what you want. If this fails, you may have its preferences accidentally switched to work online or something else. Check it is not. My friends canon was accidentally set to this and it would only print off internet, and would not communiacte offline until we checked the work offline preference in the preferences collumn. Post back if no go. Cheers,
Feb 10, 2008 | Lexmark X1195 All-In-One Printer
Printer Offline
If your problem still persists then If the printer and the printserver is on and connected to the printserver and the router respectively. Then try right clicking on the printer icon in the printers and faxes window to set it online. Try Printing. If it did not work, then right click on the printer icon again > Properties > Ports > set the proper network port. Apply the settings and try Printing.
Sep 27, 2006 | Lexmark N4000e Print Server
Lexmark X4650 InkJet Printer Logo
221 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
