Question about Motorola Mobility RAZR Cellular Phone
Vociemail language The language my voicemail speaks in is stuck in spanish. i need to change it to english.
Have a LG tracphone and the language is on Spanish, need to change to english
Kurtis, attached links will tell or show how to switch language on tracphone. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Languages on TracFone eHow
How to change language back to english on my tracfone
accidentally set my tracfone voicemail to Spanish apparently on an LG...
Jun 14, 2016 | LG Cell Phones
In voicemail it greets in spanish how do you change to english
go to settings. press languages. change the language from Spanish to English. or people calling you might speak Spanish to prank you or they're calling you from spain.
Sep 08, 2015 | MetroPCS Kyocera Hydro Life 4G No-Contract...
A disk in a series of exercise discs plays only in Spanish. My young daughter had the remote and, in a few quick buttons, made the language and writing change to Spanish only and I cannot, no matter what I...
The problem is not the disc itself but your DVD player. If other discs still play in English, and it is just this one disc that plays in Spanish, then your player is using some sort of stored setting to recognize your preference for spanish on that particular disc.
Forgive me if you've already done this, but try turning unplugging the DVD player for a period of ten seconds or so, and then plug it back in. If there is a reset button, press it. See if the disc still plays in Spanish after that.
If so, you may need to navigate the DVD menu of the offending CD to turn off the language setting your daughter selected. If you don't speak Spanish, try navigating to the language settings on one of the other discs with the English menus. Memorize how you got there, and take the same path through the Spanish language menu. Return the language setting to English, and exit.
Hope this helps.
Jun 09, 2011 | Koss KS4110 DVD Player
My computer had some loging in problems and when i took it to get fixed they changed the language from English to Spanish (where i live they speak spanish). I want it to go back to English but i cant...
You do the below seteps: This is what you do:
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages tab. If you see a drop down list of languages, see if it is set to English. If not, set to English. However, if you do not have this list there, you may need to install it.
May 21, 2011 | ASUS Eee 4G Notebook
How do I change the language mode from spanish to english? the garmin nuvi 1400 series
  • On the screen that says WHERE TO and VIEW MAP there's a TOOLS icon (Picture of a spanner.) Press it.
  • Then press SETTINGS, (the spanner icon) or on some models LOCALE (Blue Icon at the top left corner) replaces the SETTINGS icon
  • Press LANGUAGE (The lips icon)
  • On this page you'll see 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
If you need to change the text language press TEXT LANGUAGE and select ENGLISH
To change the voice language press VOICE and select the name of an English speaking voice
If you need to change the keyboard layout press KEYBOARD and select English
If the text language is in Spanish you won't know which icon is which but press each one in turn and you can change each to English. This should solve your problem.
Nov 27, 2010 | Garmin GPS
How to change the language of Microsoft Visio? The language is spanish , how to convert it to english?
Find someone who speaks spanish (outside Home Depot should do the trick) and ask them to go to Settings-->Language-->English
Jul 27, 2010 | Microsoft Office Visio Professional 2007...
I AM HAVING HTC TOUCH2 PHONE WHICH IS SPANISH LANGUAGE WANT TO CHANGE IN ENGLISH
do you read spanish ?
if not ( go to dictionary.com) and translate the words
if you do speak spanish- go to "Settings" ---> "Phone Settings" -->> "Languange" and choose english.
I dont Speak Spanish
Hope this helps
thanks
Mar 31, 2010 | HTC Touch2 Cell Phone
Language
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
Hope this helps....
Feb 13, 2008 | Nextel i530
The Phone's mode is stuck on Spanish
Press and hold the "Skip" button. I did this while the answer machine was ON. The english voice will say that the language has changed to english.
Sep 30, 2007 | GE 27992GE5 Cordless Phone
Motorola Mobility RAZR Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
