Need help setting up a friend's VR2100 video recorder. I need to set the clock and also connect the VR to a TV set. Any help would be appreciated.
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 14, 2010
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Clock will not set. Channel Guide will not
The TV Guide On Screen guide will not appear if you connect the unit to your television using composite or S-Video cables and the progressive scan option is selected.
Jul 24, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
I have a model dvd-vr 357 samsung dvd-vcr player recorder to hook up to a 2002 hitachi, and i must have it hooked up wrong.the tv is a 52 inch large screen h.d. the dvd -vcr turns on and when play is...
You need to use the video and audio outs located in the rear of the samsung player, or if you want to use the rf connector(atenna in) on the tv you need to select analog channel 3 or 4 to get a picture through, you can down load an owners manual at wwwretrevo.com.
Feb 03, 2010 | Televison & Video
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
How to set TV to VIDEO
i can help u e mail me at erwinkylevillafuerte@ymail .com i am a technician 0r call me 09085561060
Feb 01, 2009 | GE 19GT356 19" TV
Connecting an hd-tv
use optical or composite digital audio cable only from tv to receiver because with rca (red and white) you get stereo only
Jan 11, 2009 | Kenwood VR-616 Receiver
I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Nov 12, 2008 | Samsung DVD-VR357
I have a panasonic dvd recorder DMR EH50 and I know this makes me a really techno "dummy" but I can't understand how you connect the player to the tv to make it record. I've got it so I can play...
My dear friend you need to connect the signal source direct to the dvd and then to the tv.If you got cable you need to connect it to the input of the dvd and then connect the output of the dvd to the tv set.
And when you go to record put the channel on the dvd
Aug 25, 2008 | Panasonic Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
