I have a sony Trinitron kv-32fs17 and i left ON while I was working around the house. The screen went OFF by itself. I tried to turn it back ON and all I got is this red light flashing. I unplugged the TV all night and tried it again, the same thing happens. I could hear a faint clicking noise but I do not know where it is coming from. what could cause this?
    Brigadier General:
  • 8,909 Answers
The flashing led will give the engineer a clue as to where the fault may lie.
The most common number of flashes is ... well here's a list.
Hope it helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Nov 14, 2010
How can i program a trinitron soney tv model 32fs17
Please explain what it is that you are trying to program.
Is it the remote you are trying to program? Or the set itself? I can help if you give me more details.
Apr 17, 2010 | Sony FD Trinitron KD-36XS955 36" TV
TV went OFF
The standby light should be blinking in a repeated pattern. Count the blinks and report that number here. This will indicate the circuit that is defective and will allow us to provide a repair suggestion.
Thanks,
Dan
Apr 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our Trinitron KV-36XBR400 powers up then no picture
How old is this tv?More than 5 years old.Not worth it to repair CRT tv at this prices.Tries unplug,replug an hour later,might help,see if reset itself.U can buy a pretty good 32" LCD tv at $400 or less these day.It not heavy as the CRT tv,it alot easier to move the tv around the house or other locations.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Apr 29, 2008 | Sony KV-32FS13 TV
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Flashing light
UNPLUG YOUR TV WAIT FOR A FEW SECONDS AND HOOKED AGAIN, I HAVE THE SAME PROBLEM THIS RESOLVE THIS ISSUE
Sep 25, 2007 | Televison & Video
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Electro Med Services...
