Question about Ariston Technologies Ovens
My Ariston stove has consecutive numbers in the oven control knob (1, 2, 3, 4, etc,) instead of temperature numbers. How do I figure out what is the oven temperature with these numbers?
SOURCE: ARISTON OVEN
I have two sources that give correspondances between thermostat numbers and temperatures.
This is the first one:
THERMOSTATS
bullette1.gifThermostat 1 30°C - 85°F bullette2.gifThermostat 2 60°C - 140°F bullette1.gifThermostat 3 90°C - 195°F bullette2.gifThermostat 4 120°C - 250°F Gas mark 1/2 bullette1.gifThermostat 5 150°C - 300°F Gas mark 2 bullette2.gifThermostat 6 180°C - 350°F Gas mark 4 bullette1.gifThermostat 7 210°C - 410°F Gas mark 6 bullette2.gifThermostat 8 240°C - 460°F Gas mark 8 bullette1.gifThermostat 9 270°C - 520°F Gas mark 10
The other one is a formula: t = 20 X (T + 3)
where t is the température in °C
T is the thermostat (1, 2 ... 12)
As you may discover, each of the methods give slightly different results. Hope this will help.
Posted on Nov 30, 2008
  • 160 Answers
SOURCE: Ariston gas stove has 2 burners not working
the burner themocouples need replacing...
Posted on Dec 21, 2009
Testimonial: "Thanks very much you've confirmed what I thought now all I have to do is figure out how to fix them or bypass them."
  • 221 Answers
SOURCE: I don't have the model number for this range but
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Posted on Jan 16, 2010
Testimonial: "Thank you so much."
TheMobilian
  • 8220 Answers
SOURCE: i need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
Posted on Jan 28, 2010
ginko
  • 19396 Answers
SOURCE: we have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Posted on Mar 05, 2010
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Apr 10, 2010 | Stoves 720EF Electric Double Oven
I need correct temperature readings
Jan 28, 2010 | Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Dec 21, 2009 | Ariston Technologies Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Ariston oven fm51ix
new knob req Email model no and seriel no we can supply parts. regwoolley@uwclub.nwt
Jun 11, 2009 | Ariston Technologies Ariston FO98P...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
ARISTON OVEN
THERMOSTATS
Nov 14, 2007 | Ovens
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
96 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
