Question about GE Energy Star WCVH6260F Front Load Washer
Won't spin I cleaned the filter.  The machine fills with water, but won't spin for the wash cycle.  After a while the water will drain, but still not spin.  When the water drains it bursts out the hose as if something was preventing it from coming out, then the waters runs fluently.  The machine refills with water and repeats the same.  The only time I can get it to spin is when I turn it off then restart it on the rinse and spin setting.  I did this twice successfully.  Can you please instruct me on how to fix this?  Thank you
    Sergeant:
  • 225 Answers
Hi. I'm wondering if you have a "sock in the pump" situation there which might be part of the problem?
When you drain the machine and open the filter - I'm talking about the filter at the bottom of the machine where the coins and hairgrips collect - you may just be able to see deep inside the hole a little impellor which is the pumping bit. If you can see it, try to turn it round using a long pointy thing like a skewer or chop-stick. If it will turn, good; if you can see the sock, try to pull it out; and if it won't turn but you can't see the sock then you may need to access the bottom of the machine and feel the flexible rubber hoses that lead to the pump. With luck, you should be able to feel a lump in the hose which will be the problem. The hoses are usually attached by spring clips. Once you have released the clips you should be able to remove and clear the hose. If you are going to do this yourself be sure to disconnect the machine from the power socket and turn off the water first.
Another possibility is that the drain hose itself has a blockage. It's a yucky job but you might be able to get the end of the drain hose out of the house drain pipe, clean it up really well, then put some cloth like a handkerchief over the end before getting someone else to blow down it. That will often make the blockage go back to the filter chamber where you should be able to remove and kill it :-)
Does this help? If not, please give any further details you have and I'll try to think of something else. Good Luck!
Posted on Jun 30, 2008
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
JEDEMEYER1
Aug 01, 2011 | Samsung Washing Machines
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
