Question about OKI MICROLINE 320 Turbo Matrix Printer
Our okidata dot matrix 320 turbo won't stop feeding paper. i have restarted the system several times
drichards
  • 87 Answers
SOURCE: New hookup - warning light going on
Take the ribbon out and try it. The carrige also advances the ribbon, and if it is knotted up, thats the problem. Also. look for a photo interupt sensor along the edge of the carrige near the sides of the printer. Chances are, the sensor got dirty and it can not find home.
Posted on Mar 09, 2008
Laptops
  • 14 Answers
SOURCE: Feed problem
line gear has a broken tooth on it, possibly. or you have a sliver of paper stuck under the plenum (large black roller that paper wraps around to feed). you can pop the cover off, by pulling the front edge up and away from the base (clips in only, no screws). remove the plenum with tabs that pull up on either side of it. pull out the plenum, and check for any paper under that area. good luck.
chris
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: hi, the epson dot matrix
reset all cables that connected to logic board
if your problem doesn't be ended then u need to buy another logic board
Posted on Feb 20, 2009
joeshea123
  • 65 Answers
SOURCE: THE 320 OKIDATA TURBO IS
Give this a try.
let me know if this helps.
Joe
Posted on Mar 26, 2009
SOURCE: Installed a new okidata microline 320 turbo dot
HW TO SAVE AS PAPER SETTINGS microline 320 turbo
Posted on Nov 16, 2009
Okidata 186 does not feed
Are you using pin feed or friction feed? Make sure the lever on the right is in the correct position.
Apr 08, 2013 | OKIDATA - DOT MATRIX New - Oki Microline...
We had a computer crash that required replacing the computer we had with one running Windows XP w/SerPk 3. We are still using the okidata microline 320 turbo that we used with the old computer. We are a...
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
Mar 16, 2011 | Matrix Okidata Microline 320 Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
May 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I want oki ml 320 turbo driver.. eny body can help me on that..?? pls,,,,,
the oki data ml 320 driver should be bundle with the operating system. If not you can download it from okidata website.
http://okidata.com/mkt/html/nf/Drivers.html
Try it and let me know if this helps.
Thank you.
Mar 04, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Feed problem
chris
Apr 18, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
154 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
