Question about Kitchen Ranges
Need a r430b565t regulator for 5469-700 coleman two burner camping stove. ordered one from coleman but on back order!
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
SOURCE: i have an older (20
Here is Coleman's web support. I also need some work on my stove.
http://www.coleman.com/coleman/manuals/manuals_resp.asp?category_id=1100
Posted on Jul 20, 2008
docjohn174
  • 943 Answers
SOURCE: Where to order igniters for burners on gas range?
hi thanks for the question just go to goggle and type in tappan .it will take you to an appliance store near you thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
SOURCE: Stove burners will not light
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Penny
Posted on Jun 30, 2009
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Need parts
If there is no nearby repair dept, try Colemn.
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
How do you convert a coleman 425e into a propane stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Coleman instastart propane stove regulator wanted
Jun 26, 2008 | Grilling
Kitchen Ranges Logo
633 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
