Question about Black & Decker Classic Metal APP F63D Iron
Iron will not heat up when plugged into outlet
    Novelist:
  • 235 Answers
My wife has used these since they were made by Sunbeam. The majority of the times they failed it was the cord broken inside the black insulation right behind the plug. If you can get access to a continuity tester or an ohm meter (part of all multimeters) just set the meter on ohms or continuity, connect the red lead to one prong on the plug and the black lead to the other prong. If the meter doesn't read any resistance, hold the plug still and move the wire around behind it. If that results in intermittent continuity readings there is where the break is. If there is a reading on the first try, move the temperature selector to the OFF position and the reading should disappear. As you move across the range of temperatures, the resistance reading should climb. If it does not, the thermostat is bad.
Posted on Aug 22, 2012
KOakaKO
  • 135 Answers
SOURCE: Light comes on, but iron will not heat up
No electricity is getting to the heating coil inside the iron. It has to be disassembled to find out if the heating coils are broken, or just not connected properly.
Posted on Aug 09, 2007
Maanita
  • 1142 Answers
SOURCE: iron is plugged in but
check the thermostat roll switch it must be turned down to off mode select the cloth type u want to iron thten it should work.
Posted on Apr 22, 2008
geox29
  • 65 Answers
SOURCE: Why isn't my Iron heating up?
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Posted on Jun 19, 2008
oliso iron turns on when plugged in green light flashes but iron will not heat up
Posted on Apr 11, 2009
  • 19 Answers
SOURCE: shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Posted on Aug 16, 2009
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My iron does not heat up
The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
Mar 07, 2011 | Oliso TG1050 Iron with Auto Shutoff
My Rowenta iron will only heat when plugged into one specific outlet (other things work in the outlets that the iron "doesn't like"), and sometimes it will only heat if you giggle the cord around a bit in...
Sounds like the plug and/or the cord are bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 05, 2009 | Rowenta Perfect Iron
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
My toastmaster steamxtreme iron was left overnight plugged into the electrical outlet. I thought it had an auto-shut-off? Now it won't heat up. Any suggestions?
unplug your iron, turn the dial to off.. then plug it in and turn the dial back on. this will reset the auto-off
Aug 15, 2009 | Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Feb 13, 2009 | Irons
Shark G1490 doesn't light up or heat up when I plug it in.
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
Iron is plugged in but does not heat up. I have tried multiple outlets
Apr 22, 2008 | Black & Decker D2030 Iron
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Aug 09, 2007 | Sunbeam Safety Glide 3891 Iron
Black & Decker Classic Metal APP F63D Iron Logo
309 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
