Question about Goodman CKL24AR24 Air Conditioner
I have a goodman ar24-1 blower motor that will not start. I have changed the capacitor, checked the thermostat, spun the blower motor but still will not start. Outside unit runs but no blower. Any ideas? This is a central air unit that is less than 6 years old.
  • 674 Answers
Check the relay or sequencer that controls the blower if it has one of those. If the fan is controlled by a circuit board then you problem may be there. If it is controlled by a circuit board then you can check for power at the fan connection when the fan is supposed to be on. Then there is always the possibility that you blower motor is burned out. You can use and ohmmeter to check the motor windings. You said you checked the thermostat, how did you do that? If you install a jumper between the R and G connections the fan should run if everything else is OK.
Posted on Nov 15, 2010
Goodman aepf426016aa
Communication problem. You say condenser stat and power are fine? if that means the condenser runs but the air handler doesn't that means the communication is good and the blower is not running. That may be a capacitor (you must have ammeter capable of checking microfarads) if not that check power it may be board driven. If no power to blower the board is bad assuming power is at board. If that is ok the blower motor is bad.
Nov 29, 2013 | Goodman Heating & Cooling
Blower motor turns on then shuts off after a minute on my goodman furnace
The motor is shutting off on it's overload. Make sure the capcitoris the proper voltage and microfarad rating. Also, make sure two speeds are not hooked up at the same time to the motor, for example if there is a motor lead on the heat terminal, there should not be one on heat/cool terminal. If all checks out good younwill need a new motor
Jan 01, 2013 | Goodman Heating & Cooling
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
Indoor blower not running,capacitor is good,blower motor is good
have you check the 24 volt transformer in the air handler? you must have 24 volts from the thermostat to the tranformer in the air handler.
Jun 23, 2010 | Goodman CLJ30AR32 Air Conditioner
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Phkj048 outside fan does not start unless it is spun
Replace the start Capacitor  on the motor, if it has one, else if it does not ,replace the motor as the start windings insuide of the motor are no longer workng.
Jan 03, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman GMP125-5 Air Handler
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Jan 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman CKL24AR24 Air Conditioner Logo
560 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
