Question about GE Refrigerators
Refrigerator is only going down to 50.2 degrees and there is frost on back wall of freezer.
  • 1,531 Answers
The frost on the back wall of the freezer is a usuall indication that there is a problem with the defrost circuit,defrost heater,thermastat, or the defrost timer.you can use a blow dryer and defrost the evaporator coil.remove the rear panel in the freezer to gain access to the evaporator coil.you also need to make sure that the evaprorator fan is functioning properly.
Posted on Nov 14, 2010
My freezer temp is at 25 degrees...WHY??
Are fans running? Any frost buildup on inside back freezer wall?
Nov 17, 2017 | GE PFS22MIS
Whrilpool refrigerator will not cool.
First, put the control back to it's normal setting. Turning it colder is not going to help. Then check the obvious, the coils underneath need to be cleaned, and the fan needs to be running. And check to see if there is a heavy frost on the back wall inside the freezer. If there is it could indicate a defrosting problem. Both will cause the temperature to rise. Also, be sure the fan in the freezer is running.
Jan 06, 2010 | Whirlpool ES5FHAXS Side by Side...
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
The refrigerator temperature ins 50 and the freezer is 15. Is this the appropriate temperature? The butter is soft at this temperature
the fridge should not be above 40 degrees and the freezer not above 30. check back wall of freezer for frost. if so, coils are iced up and need to be defrosted. either take off back wall of freezer and melt ice with warm water or hair dryer, or unplug unit and let it set with doors open for a day. then clean up the water.
Jul 20, 2009 | Jenn-Air JCB2280HES Side by Side...
GE refrigerator Model#GSS25JFMD Refrigerator is at 50 degrees, freezer at 34 with the dials turned all the way up. Any previous experience with this?
Check for frost about 1 foot up on the back wall in the freezer section . Is so , then a defrost problem is there .
Jul 16, 2009 | GE GSS25JEMWW Side by Side
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Nov 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
